need help!!!!
Old Apr 10, 2002 | 09:34 PM
a-4cefed's Avatar
Default need help!!!!
abs light came on, along with the brake light. the brake light is flashing what does this mean?
Old Apr 11, 2002 | 02:42 AM
audifirst's Avatar
Default either the sensor is disconnected, or malufunctioning need to be replaced
but first check front for any cable loose , remove the front tires and check if the wire is cut or the connector on hub is loose, you can the connector on the side of the hub, that is abs sensor...
magillsp
Apr 21, 2009 10:38 AM
mole32
4.2 V8 Discussion
Oct 4, 2008 05:14 PM
MichaelA
Brakes Discussion
Oct 7, 2006 11:10 AM
Younger
Jul 10, 2006 05:37 AM
DrRings
Apr 7, 2004 07:48 AM
