need help
Old Nov 12, 2005 | 07:26 PM
Q's Avatar
Q
Default need help
My 1996 A4 overheated today on the freeway. Car cut off by itself but I was able to coast to a gas station. The expansion tank was empty and I had just filled it a couple of days earlier. I purchased some antifreeze and let the car cool down but it would not start. I could hear the starter whine but engine would not turn over. Any Ideas? Car has 130000 miles and last timing belt change was at 90000 miles. I was thinking maybe a new water pump but why wouldn't the car restart?
Old Nov 12, 2005 | 07:38 PM
WJM's Avatar
WJM
Tech Guru
Default sounds like you may have seized the engine.or have a hole
overheating isnt something you let your car do... Did you find the source of your leak?
Old Nov 12, 2005 | 07:48 PM
gh0st's Avatar
Default You let it overheat until it turned off?
How long was it above normal temps? Doesn't sound to good
Old Nov 12, 2005 | 08:30 PM
Q's Avatar
Q
Default Re: You let it overheat until it turned off?
maybe 5 minutes if that...temp guage only went about 3/4 way over center which is my normal temp.
Old Nov 12, 2005 | 08:32 PM
Q's Avatar
Q
Default Re: sounds like you may have seized the engine.or have a hole
no...and expansion tank fills up. It is not leaking, it is being used.
Old Nov 12, 2005 | 08:40 PM
Q's Avatar
Q
I think the water pump may have failed but that still does not explain why it wouldn't start after I let it sit. I got it home and put it on the charger for a while and it still won't start.
Old Nov 12, 2005 | 09:06 PM
pmark837's Avatar
Default you may have warped the engine from overheating, so it's "seized"
or hopefully it wasn't the timing belt that broke. but only 40k shouldn't do that.
Old Nov 12, 2005 | 09:30 PM
Q's Avatar
Q
Default Re: you may have warped the engine from overheating, so it's "seized"
Tried to "Pop the clutch" to start the engine. That didn't work either
Old Nov 12, 2005 | 10:00 PM
pmark837's Avatar
Default did the clutch slip on you/ did the car just completely jolt to a stop? btw, change ur subject .....
line to what you are trying to say instead of just writing it in the message area. like what i did.
Old Nov 12, 2005 | 10:15 PM
Q's Avatar
Q
Default No, it didn't "jolt" to a stop...
No it didn't "jolt" to a stop. I think the clutch may have been slipping...I think...Am I looking at a new engine or is this something that can be fixed?
