need help clearing code
Old Jun 4, 2012 | 12:20 PM
97beautifulaudi's Avatar
Default need help clearing code
i have the code p0116 i need help clearing... i recently had 9 codes p0134 , p0116 , p1101 , p0150 , p0130 , p0154 , p1106 , p0155 and p1602. i replaced all four oxygen sensors and everything was clear...after about 30-60 minutes of driving the p0116 code came on. i know it can be o2 sensor related but don't believe thats the case since i bought all four new and they cleared the other codes. i can't find any vac leaks or anything unplugged. any ideas?
Old Jun 4, 2012 | 12:24 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Gosh, I wish I new what all those numbers meant. I guess we're both too lazy to look them up.
Old Jun 4, 2012 | 10:16 PM
Typ89's Avatar
Did you look up the code? Its an ECT sensor code, there's a few possible causes but most common solution would be ECT sensor replacement unless its your thermostat, if you car does not warm up or stays warm (on highways) . I had that code when my tstat went.
Old Jun 5, 2012 | 06:41 AM
when its sitting there idling its inbetween c and h like it should but on the highway its at c or below it...so its the thermostat
Old Jun 5, 2012 | 10:01 AM
Typ89's Avatar
Yeah sounds like it. I would recommend changing timing belt idler and tensioner pulleys and water pump since you're going to be there anyway.
Old Jun 5, 2012 | 12:23 PM
GTA_Driver's Avatar
Tech Guru
If he has 1.8T, I am pretty sure the thermostat can be changed without putting the car into service position and accessing all timing components.
Old Jun 8, 2012 | 05:03 PM
AudiMick's Avatar
Four oxygen sensors suggest a V6.
HIS4
VAG-COM Discussion
Mar 16, 2007 09:55 AM
Sloooo4esT
Audi Original "S" Cars
Sep 15, 2005 08:35 AM
myvw777
VAG-COM Discussion
Oct 27, 2003 04:17 PM
eroc
Feb 1, 2003 06:01 PM
Jeremy Clarkson
23
May 1, 2002 06:44 PM
