Need help with fuel issue?
I have a 98 2.8 B5 and when the car is cold started (like after around 6 hours or so or overnight) it has a somewhat of a rough start at idle (around 1200-1400rpms) for around a minute or two and then goes down to 750-800rpms afterward. This has been going on for a while now, but since last week I've started to hear a high pitch noise from the front right-hand corner under the hood. It's coming from under the air intake where the A/C pipes seem to connect to the compressor?? I'm not quite sure what's causing it, but it goes away when the engine gets done with the rough idle phase.
Also, since yesterday, out of no where the car suddenly stalls when I shift to idle while driving (not all the time, but it happens quite often).
Here are the codes I got from VAG-COM. I'm guessing it's something to do with my fuel system (but that doesn't explain the noise). Would really like to get some input if some of you have experienced something similar to this.
P1237 - 35-10 - - - Intermittent
17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
P1238 - 35-10 - - - Intermittent
17647 - Fuel Injector for Cylinder 3 (N32): Open Circuit
P1239 - 35-10 - - - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 - 35-10 - - - Intermittent
17649 - Fuel Injector for Cylinder 5 (N83): Open Circuit
P1241 - 35-10 - - - Intermittent
17650 - Fuel Injector for Cylinder 6 (N84): Open Circuit
P1242 - 35-10 - - - Intermittent
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-00 - -
17537 - Fuel Trim: Bank 2 (Mult): System too Rich
P1129 - 35-00 - -
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-00 - -
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 35-10 - - - Intermittent
I can't think of a relationship between the SAI pump and those fuel codes.
