Need Help with remote start.
Old Feb 8, 2004 | 02:10 PM
00bluea4's Avatar
New Member
Default Need Help with remote start.
I just installed a viper 791xv. The problem is that when I try to start with the doors locked the factory alarm goes off. If I start within 30 seconds of arming the alarm will unlock the drivers door - start - then relock. but if i wait longer than the 30 seconds the horn and lights go off. Any suggestions will be a big help. Thanks
Old Feb 8, 2004 | 02:40 PM
wblakes's Avatar
New Member
did you hook the disarm wire to the unlock wire?
Old Feb 8, 2004 | 03:56 PM
00bluea4's Avatar
New Member
Default Re: did you hook the disarm wire to the unlock wire?
I tried that but the locks did not work right. When I push lock (arm) it would lock then unlock right away.
Old Feb 8, 2004 | 07:26 PM
Fuel100's Avatar
New Member
Default You don't need to disarm the factory alarm.
You only need to bypass the factory alarm's ignition sense wire. This also leaves the stock alarm armed while running.
Old Feb 9, 2004 | 03:09 AM
00bluea4's Avatar
New Member
Default Re: You don't need to disarm the factory alarm.
Where can I find the ignition sense wire?
Thanks
internecine
Feb 21, 2008 10:23 AM
TheBeanS4
May 3, 2004 10:31 AM
audijim113
Audi 100 / A6 (C4 Platform)
Mar 11, 2004 02:49 PM
u__u
Nov 23, 2003 01:37 PM
