Need help w/electrical problem....
Old Jan 13, 2004 | 04:55 AM
BostonBrian's Avatar
Default Need help w/electrical problem....
Last night when I was leaving work the headlights, outside temp display, heater fan motor ONLY, blinkers, wipers and rear wiper fuse were all dead.
Parking light, highbeam (only by pulling toward me) still work.
All the fuses by the driver's door are fine.
I'm thinking some main relay might have fried.
Has anyone expereinced these symptoms?
Does anyone have any insight on what to check?
Thanks.
Old Jan 13, 2004 | 05:01 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Sounds like maybe the load reduction relay is toast...
if your fuses are fine, then there is no power getting switched through them. Use a multimeter or 12v test light to see if you have power on either side of the fuse when the key is on..
Old Jan 13, 2004 | 05:06 AM
Thanks Kris. This relay, is it under the knee bolster?
Old Jan 13, 2004 | 06:27 AM
Head Cat Herder
25 Year Member
Default Yep. I am not sure which one it is, I don't have my Bentley here...
I've never had to play with this one. In days of old, the load reduction relay was orange, not sure if it still is.. Basically it's a high current relay, to take the load off of the ingition switch.
OUTY1hundy
Audi 100 / A6 (C4 Platform)
Oct 6, 2012 04:26 PM
enigma1406
Mar 7, 2007 06:10 AM
cgtracer
May 2, 2006 01:42 AM
audiman231
Feb 16, 2004 05:25 PM
Kiloechoxray
May 31, 2003 08:04 PM
