No Check Engine light while in the On position
Old Aug 24, 2004 | 02:39 PM
DoubleDose's Avatar
New Member
Default No Check Engine light while in the On position
Engine doesn't run either. Just got my ECU socketed with a GIAC chip, and it ran great from when I put it in till now. I think I installed it around Friday night and made sure to do the throttle-body adap, and maybe put 5-600 miles on it. Ran like a Banshee man, really fast. Pulled up to a stop light and when I gave it the gas the engine died and I coasted into a gas station. Now the check engine light DOESN't come on and the Evo MS guys said it should. Need some advice to say the least.
Thanks,
DD
Old Aug 24, 2004 | 03:09 PM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Check the ECU connections, and the socket if you dare.
Audilanche's Avatar
New Member
Default I believe that means the car is not communicating with the ECU. Make sure the ECU is plugged
in correctly and the chip is socketed correctly.
Old Aug 24, 2004 | 04:24 PM
Flash256's Avatar
New Member
Default Had that happen on mine - had to replace the ECU chip socket -
Think they called it a decryptor.
Old Aug 24, 2004 | 08:27 PM
Mark1.8T's Avatar
Junior Member
Default Tap on the ECU and see if the CEL comes on, then you'll know it's the chip.
Happened to me with my APR. Had to send it back to get it resoldered... twice!
Old Aug 25, 2004 | 08:11 AM
DoubleDose's Avatar
New Member
Default Problem == GIAC Chip died...
Evo MS must have given me the Micro$oft Windows version of the chip because damned if I just didn't get a BSOD (Blue Screen of Death) from my car. Thank God I had my ECU socketed and was able to swap the GIAC out for my stock chip. Sending the GIAC chip back to Evo MS today to get it fixed/re-flashed/ported to Linux. Now I'm just driving around making vroom vroom sounds as my car feels slower than crap now. Man that chip is the friggin shiz-nit, and thought it was just 1.0 bar and not 1.3 bar! Hmmm, gonna have to get some race gas I'm thinkin'. Wife will love that one...
Thanks for all your help and a definite shout out to Mark1.8T cuz he's always answering my n00b posts with exactly what the problem is and what I need to do to fix it. You da man Mark!
DD
Old Aug 25, 2004 | 05:06 PM
Mark1.8T's Avatar
Junior Member
no problem. good luck, hope it all works out.
Old Sep 8, 2004 | 02:24 PM
DoubleDose's Avatar
New Member
Default Solution to my problemo, Always socket your ECU
Sent the chip back to Evo MS and got it back the next week. Socketed it back in and everything ran fine. Best $40 I ever spent to be able to swap out my ecu's. Whew...
 Pouria Savadkouei
 Michael S. Palmer
dyswtric27
Apr 8, 2005 12:31 PM
Paul TTINGER
9
Apr 29, 2003 05:41 PM
blueT28EnYcEe
Jun 3, 2002 04:29 PM
buzlin
Apr 18, 2001 06:19 PM
5th Screw
Nov 21, 2000 07:27 PM
