Normal when cold or problem?
Old Feb 15, 1999 | 03:59 AM
M. Ivy
Guest
Posts: n/a
Default Normal when cold or problem?
Are the following problems normal for an A4Tip? Both of the below issues normally occur when the car is cold.<p>1) Even after allowing the engine to warm up, the transmission will allow the engine to rev pretty high before upshifting. This happens during the first one (or sometimes two) starts from a stop. Normal or a problem?<p>2) The brakes sound like they are grinding during the first few stops. The grinding sound always disappears once the brakes have warmed up. Normal or a problem?<p>Any information would be appreciated.<p>Thanks,<br>M. Ivy<br>Black/Ecru 2.8QTS
Old Feb 15, 1999 | 04:19 AM
Roy M
Guest
Posts: n/a
Default I would say normal.
You will find that first shift of the morning is always slow. Mine normally occurs at 3000 RPM. Be a little gentle for the first few minutes and all will be smooth and silky. We have been told this is due to emissons control. Audi want to accelerate the warm of the motor for emission sake.<br>The brake grinding noise is most likely the removal of the surface rust that develops on the rotors over night. I have noticed this on all the disk brake equipped carsI have owned.<p>So don't worry and enjoy your Audi A4<br>Roy M 98.5 2.8q Tip
Old Feb 15, 1999 | 06:52 AM
stevebrown
Guest
Posts: n/a
Default Number 1 is a feature
gets the catalyst warm...don't think waiting for the engine to warm up will override it.<p><br>steve
Old Feb 15, 1999 | 12:54 PM
M. Ivy
Guest
Posts: n/a
Default Thanks for the info.
nt.
kula009
A4 (B9 Platform) Discussion
Jan 16, 2018 07:47 PM
q5.kw
Q5/SQ5 MKI (8R) Discussion
Jan 22, 2011 07:48 AM
j2mc
Jan 19, 2009 06:16 PM
Bozman
Dec 8, 2002 06:40 PM
