O2 sensor - what's the part # and how to check with VAG-COM that it's really failing?
Old Apr 8, 2005 | 04:41 AM
ex-quattro PETE's Avatar
AudiWorld Expert
Default O2 sensor - what's the part # and how to check with VAG-COM that it's really failing?
I pulled this code:
16517 - Oxygen (Lambda) Sensor B1 S1: Response too Slow
P0133 - 35-10 - - - Intermittent
but since it's intermittent, is there another way to check with VAG-COM if it's going bad? Which engine measuring block to log and what values would indicate that it's bad?
I'm thinking it's block 34 (see link), but do I measure this at idle or at certain rpm/engine load?
Also, anyone got a part number for that O2 sensor in question? How much labor is involved in getting it replaced?
Thanks!
FYI, it's a 2001.5 A4 1.8TQM (AWM)<ul><li><a href="http://www.ross-tech.com/vag-com/m_blocks/030-049.html">http://www.ross-tech.com/vag-com/m_blocks/030-049.html</a</li></ul>
Old Apr 8, 2005 | 06:06 AM
minbo's Avatar
New Member
Default Re: O2 sensor - what's the part # and how to check with VAG-COM that it's really failing?
There was a post similar to this in the VAG group:
https://forums.audiworld.com/vag/msgs/6835.phtml
They were pointed to this link:
http://www.ross-tech.com/vag-com/cars/fuel-trim.html
Old Apr 8, 2005 | 09:10 AM
AudiWorld Expert
Doesn't really help answer my question, but thanks - I'll ask there.
Old Apr 8, 2005 | 09:26 AM
minbo's Avatar
New Member
Default Re: Doesn't really help answer my question, but thanks - I'll ask there.
I thought that perhaps the trim link could help you with determining if the O2 sensor was really failing as your trim would possibly be off by an amount greater than 10%.
Old Apr 8, 2005 | 09:56 AM
AudiWorld Expert
Right, but there can be many other reasons for incorrect trim as well.
RedDragoN750
Audi 100 / A6 (C4 Platform)
Nov 4, 2008 02:38 PM
Drake H
Mar 14, 2008 06:12 AM
nikhil
Performance and Tuning
Sep 24, 2006 04:43 PM
ex-quattro PETE
VAG-COM Discussion
Apr 12, 2005 12:05 PM
trav
Misc. Models Discussion
Feb 4, 2001 01:09 PM
