odd behaviour
Old Aug 29, 2005 | 07:56 AM
djpaudi's Avatar
New Member
Default odd behaviour
Hi-
So I have this weird noise/sensation coming from my brakes. I replaced my front pads/rotors (they were due to be changed anyway), and the problem persists. Basically, when turning and simultaneously braking, I get a grinding/groaning and along with some shuddering in the brake pedal. Goes away when I apply more pressure. It probably isn't the control arms, as I also had all those replaced a few months ago and visually, they appear fine. I'm concerned that since the noise isn't consistently reproduced, and it sometimes happens even while braking and not turning, it might be the wheel bearings or something more serious. Or could it just be chatter in the brake calipers?
Has anyone else experienced this sort of symptom?
Thanks,
Dan
Old Aug 29, 2005 | 08:02 AM
Silver Streakin''s Avatar
Member
loose lugs? torque to 89 ft-lbs
Old Aug 29, 2005 | 08:39 AM
computrtutr's Avatar
Default ABS?
Just a thought, but is it possibly ABS kicking in? This could be due to system malfunction, driving habits, etc. If you don't know what ABS feel like, it feels kinda like a tranny grind when you're driving stick.
de (-eeez_nutz)'s Avatar
AudiWorld Expert
Do you have some build-up on the rotors?
Old Aug 29, 2005 | 08:50 AM
djpaudi's Avatar
New Member
Default Re: Do you have some build-up on the rotors?
don't think so. the rotors are brand new as of this weekend... as are the pads.
Old Aug 29, 2005 | 08:53 AM
Default Did you bed them in?
If so, how?
Old Aug 29, 2005 | 09:03 AM
Default Calipers/slides
You may also want to check your calipers to see if they move (Did you re-lube the slides when you did the brakes?). Also, did you use the anti-squeal brake lube on all the functional non-braking surfaces?
Old Aug 29, 2005 | 09:13 AM
djpaudi's Avatar
New Member
Default Re: Calipers/slides
Ahhh, yes I bedded the brakes in, lubed the caliper slides, and used antisqueal compound on the brakes. the thing is that this was happening before i changed pads/rotors, so I think it is something more nefarious.
 Michael S. Palmer
Old Aug 29, 2005 | 12:37 PM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Pulsing in the brake pedal? Is it the ABS kicking in?
If you want, next week (I'm on 'vacation' this week..), swing by my work again, I'll have a look!
Old Aug 29, 2005 | 01:50 PM
Default Good info!
This helps the diagnosis! I did not know you had the problem before the brakes. How are your CV joints? Boots intact? How about the inners?
