Oil problems
Old Jan 4, 2008 | 07:43 AM
BigBobELK's Avatar
Junior Member
Default Oil problems
Yesterday pretty much all my oil leaked out of my car. I started it , ran inside to grab my stuff and came out. I opened my door and then i heard a gurgling noise. I immediately shut the car off and looked underneath to see oil pouring onto the ground. I took a quick look and saw that the oil looked like it was coming from where the oil filter screws onto.
Before i rip my car apart looking for the exact problem is there anything i should look at first? Its a 98 1.8tQM chipped. Everything was fine up untill this happened AFAIK.
TIA
Old Jan 4, 2008 | 07:50 AM
Vier Glühende Ringe's Avatar
Default Pull off your valve cover and pull a cam bearing cap from the front side of the motor (farthest from
oil source) and inspect for damage. You will need to take off your oil filter, replace the oil cooler o-ring and retighten oil filter union and nut and install new oil filter and oil.
Old Jan 4, 2008 | 08:32 AM
Silver Streakin''s Avatar
Member
was/is the filter tight? check to see if the nut for the oil cooler is loose.
Old Jan 4, 2008 | 08:51 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default That used to be an issue with the late 1980's VW 1.8 engine. Oil pressure relief valve stickage.
Happened in cold weather. Check your oil pressure too.
Old Jan 4, 2008 | 08:52 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
Default I had that happen with a cheap filter back in my college days
I only use OEM for my Audis now
Old Jan 4, 2008 | 09:12 AM
BigBobELK's Avatar
Junior Member
oil filter is tight. i think it may be the oil cooler.
Old Jan 4, 2008 | 09:37 AM
Gordan T.'s Avatar
Default There is an o-ring behind the oil cooler. This can degrade and fail catastrophically...
...resulting in a rapid oil dump. After STFA-ing and finding the horror stories, I just replaced mine yesterday, because I've had what looks like an oil leak pooling under the oil filter. The old ring was hard, not pliable, but it wasn't broken, so I don't know whether that was the cause. Tough to tell whether the leak has stopped - it almost looks like the oil cooler itself is leaking at the seam, but I don't know whether that should be possible - does the coolant "jacket" surround the oil "jacket" in the oil cooler, or is it the other way around? There's no oil/coolant mixing that I've been able to detect, so it's not an internal crack.
Old Jan 4, 2008 | 09:44 AM
BigBobELK's Avatar
Junior Member
Yea i believe this is my problem also. How hard of a job is this and is there a write up?
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 4, 2008 | 09:56 AM
UK_Audi_A4's Avatar
New Member
Default Check the Oil Pressure switch too!
Its located above the oil cooler.
Old Jan 4, 2008 | 10:00 AM
BigBobELK's Avatar
Junior Member
Default Update: Its the oil cooler seal. Trying to find it locally but it doesnt like like its happening.
Seems to be a pretty easy job.
