one headlight doesn't work
I pulled the cluster**** apart and the bulb looks fine. The filament seems fine. hmm.
I notice some plastic hanging out there. yeah, somebody broke off a piece of the ring that holds the whole thing together.
So thats where im at right now.
so this brings me to 3 main questions.
1. why doesnt the light work if the bulb is fine, should i check the voltage of those wires with the lights on?
2. How do i get the headlights off the car. I wanted to glue the piece back on, and if thats not possible, get a new headlight.
3. The other light still works and the high beams on that side work. WTF is up.
oh and 4. why the hell does audi have to make things soo much more complicated then they are.
Where is the relay? i just want to check that before i buy the part.
My corner lights do still work, so would that still indicate that the switch was bad?
Mine was 99 a4 I was refering to. The corner lights still did work, actually all lights worked except the low beams. One quit working and about two days later the other quit working, all other lights still worked.
Incase you wonder
fuse 21 driver low beam - right below 20
fuse 18 passenger high beam
fuse 19 driver high beam
hope this helps
