Oxygen (lambda) sensor again
Old Mar 16, 2005 | 06:08 PM
rallychk's Avatar
New Member
Default Oxygen (lambda) sensor again
Saw several posts but none that said they found the solution. Was wondering if anyone had the solution.
I replaced the bad sensor (with OEM), had a shop clear the code, and still the Check Engine light comes back on as soon as I hit 2,500 RPM.
Another shop tested it and said there was no power to the unit - so replacing it did nothing.
Has anyone found the solution to this?
Thanks,
Benedikte
Old Mar 17, 2005 | 07:46 AM
BigEd's Avatar
Member
There is not enough info in your post. Any way you could provide the codes the shop pulled?
Old Mar 17, 2005 | 09:05 AM
rallychk's Avatar
New Member
Default Oxygen Sensor codes
The code is:
16545 - Oxygen (lambda) Sensor B2 S2:Heating Circuit Malfunction P0161 - 92-00 - Unknown Error Elaboration.
Thanks
Old Mar 17, 2005 | 10:33 AM
BigEd's Avatar
Member
Default This looks like an electrical problem with a circuit that feeds the heating element in that O2
sensor. Possible reasons:
1. Generic aftermarket sensor (this happened to me when I've replaced my pre-cat OEM sensor with an aftermarket one, - it worked fine but triggered the CEL. I ended up returning it and spending more money on an OEM sensor)
2. Problem with the sensor connector or wiring (you'd need to get a voltmeter and start checking).
3. Problem with the ECU (this is extreme and very unlikely).
Since your problem didn't go away after the sensor replacement I am thinking you have a connector/wiring problem. Someone need to dig around with the voltmeter, checking voltage from the sensor up towards the ECU.
Old Mar 17, 2005 | 10:57 AM
rallychk's Avatar
New Member
Default Electrical problem
Thanks - it was an OEM replacement so I will staRe: This looks like an electrical problem with a circuit that feeds the heating element in that O2rt checking things over with a voltmeter.
clueless racer
25
May 10, 2014 04:25 PM
Kahuna-Big
Dec 18, 2009 06:23 PM
audiquattroduo
11
Nov 13, 2008 02:46 AM
Boston Driver
Jun 4, 2008 09:48 AM
DanosS4
10
Nov 1, 2007 09:46 AM
