P1340 Need Help Fixing...
Old Oct 7, 2008 | 06:59 AM
RICHIES_AUDI's Avatar
New Member
Default P1340 Need Help Fixing...
So far I have replaced:
3 Engition Coils
Cam Tensioner
Cam Position Sensor
Timing Belt
Timing Belt Tensioner
Water Pump
I have the same problem with the cam timing. I have checked the TDC position already 3 times.
With the cam tensioner plugged in the car make a clicking sound while its seems to be trying to adjust. While the tensioner is unplugged you don't have this sound.
What controls the Cam Tensioner?
I have heard you can check the signal wave from the harness to the ECM. Any help would be much appreciable.
Also, maybe checking the signal from the cam position sensor would be another guess as to causing the fault.
Old Oct 7, 2008 | 08:14 AM
Joey T
Guest
Posts: n/a
Default What is the actual VAG code?
You will need a VAG COM for this repair.
Old Oct 7, 2008 | 11:45 AM
New Member
Default P1340 is the code I keep getting from. Engine Plausability...I think.
I have a VAG COM...
Old Oct 7, 2008 | 12:24 PM
Joey T
Guest
Posts: n/a
Default If youhave a vag com, it should not be giving you a p code.
P codes are generic. It should be a five digit code. If you have anything but an actual VAG-COM I don't think it will work.
When did the code start? Year, make model? Have you been doing synth oil changes every 3k, with the correct filter?
Old Oct 10, 2008 | 07:54 AM
New Member
Default Here is the same problem I was having before except one of my coils was out. Fixed one problem.
Fix the problem with faulty coil but have a timing issue with the engine. My guess it is wiring or ECM fault. I cannot live with the problem anymore so I took it in this morning for diagnostic...$100/HOUR!
Check the URL.<ul><li><a href="https://forums.audiworld.com/a4/msgs/2798063.phtml">https://forums.audiworld.com/a4/msgs/2798063.phtml</a</li></ul>
Old Oct 10, 2008 | 08:34 AM
Joey T
Guest
Posts: n/a
Default And you could have bought a VAG-COM and fixed the issue by now.
A fool and his money.....
Old Oct 14, 2008 | 05:47 AM
New Member
Default Dude I have one...It was the timing was off. I Have been driving for a couple of days now.
So I had to realign my timing belt it was off a tooth. Turns out there is a mark on the crank pully and the outer crank case. This would of been helpful if the procedure would have called this out. I couldn't find any of the procedures posted on here that call that specifically out to check. Before I noticed the markings on the case I used the TDC from spark plug one turning the crank.
I have been driving a couple of days and I just got a code 17536(P1128) Long Term Fuel Trim Mul. System too Lean (Bank 1) INTERMITTENT
PEvans
Jan 24, 2013 03:55 PM
speed/efficiency
Mar 28, 2011 10:53 PM
jschick
Oct 28, 2010 04:55 PM
typ44q
Mar 24, 2009 05:30 AM
grandA401
30v V6 Discussion
May 25, 2007 07:37 AM
