PCV stuff
Anyone else seen this? Is there any sort of valving in the head to control PCV flow? (because the Germans can't have enough moving parts.) I will replace the one side and depending on cost the drivers side too. Anything else I should look for that could restrict crank case breathability? Is there a section in the manual that discusses this that I missed?
Thanks!!!
Andrew
I ran water in the hose and it does not appear that there is any valving in the hose. It is just a hose. I will replace them as they both are looking original and 200k miles will take its toll and pray that I don't have any more oil pan leaks.
I assume you have a 1977 911. Which if I am not mistaken has the 915 transmission. I also assume that if you still have the car you have had to rebuild. (how am I doing here?) I have been trying to get a handle on how long the average tear down and rebuild on the 915 takes and no one will give me a number. 3 hours? 30 hours? what are we talking about?
Thanks!!
Andrew
The plenum is the plastic duct behind the throttle body. Disconnect the vacuum lines and there are two 10 mm bolts holding it down.
Probably not worth replacing. The blow by on this engine is pretty common.
It's generally worse in the winter I have cleaned it three times (I am at 160kmiles)
Running water through is not an indicator. We've a 96, as well as a 00 V6 A4, and the pcv's don't seemingly last much more then 50-60k before they start increasing crankcase pressure's enough that its pushing through upper end gaskets. I tend to replace them when I do the timing belt/waterpump combo every 60k. This has basically eliminated oil leaks in our cars completely. Its also a good idea to keep an eye on the oil pressure switch.
That still doesn't really answer the question of what is that goop in the "pcv hoses" (for lack of a better term) or should I not worry about it. Replace the hoses, put oil in and drive off into the sunset, right?
Thanks for the advice on the maintenance I will put that into the routine and pray for the best! That is the one thing that I am very much missing on my A4 (that my 911 has) an oil pressure gauge! The only time I have ever seen the usefulness in the oil temp is when I was chasing a Bently on I70. I found that the motor redlined at 125MPH and the only gauge that changed was the oil temp as it steadily increased. (Ah! That is why I am running Mobil 1!)
Is there a "mod" to replace the oil temp with pressure? or a pressure gauge that could be mounted somewhere so that you don't look like a ricer or a trucker?
Thanks!!
Andrew
http://www.purems.com/products/product.php/II=1584
It's from purems and costs about $56? I have the same sight burning oil smell while idling and sometimes slightly smell it in cabin every now and then but have no oil leaks that I can see. I thought it was valve cover gasket. Admittedly, I haven't looked that hard for leaks, but see none on driveway.
