Please help with these code pulled from VAG
Old Mar 6, 2007 | 02:00 PM
Pekboy's Avatar
Default Please help with these code pulled from VAG
I've tried searching for the 01203 and based on the result, it looks like the possibility of having a faulty ABS controller is higher than a bad instrument cluster. I wasn't able to find much information on the 18015 error code. Since they both are related to a bad instrument cluster, I'm afraid simply replacing the ABC controller and turns out it's not the cause of my problem. Any suggestion is appreciated. TIA
Old Mar 6, 2007 | 02:16 PM
a4 4snow's Avatar
Default do you have a flashing ABS light? that some times also beeps
if so its most likely the ABS. at least thats what happed with my car.
Old Mar 6, 2007 | 02:38 PM
Pekboy's Avatar
no flashing ABS. Just a flashing Brake light accompanied by a lite ABS light w/3 beeps
Old Mar 6, 2007 | 04:50 PM
a4 4snow's Avatar
Default sounds like the ABS i knew mine was out when i went to the
snow and the brakes just lock up.
Josh5442
Nov 6, 2005 06:08 PM
Josh5442
Nov 3, 2005 12:31 PM
velo
Sep 19, 2004 03:46 AM
A4 C
Apr 21, 2004 10:42 AM
RTB
Dec 15, 2003 03:15 PM
