possible answer to weird problem?
thanks agian,
brian 98.5 A4 1.8Tq
The first time, it was towed to a dealer, and they replaced the battery and the problem seemed to go away. I was skeptical, since we had tried to jump start the car, which should have worked if the battery was the problem.
So two weeks go by, and it happens again. This time it is towed to a different dealer and I explain everything that has happened and even give my thoughts on what the problem is. The dealer finds the problem immediately. They called it an "ignitor" switch (???). Anyway, it's a switch that is attached to the clutch pedal and the switch was bad. Another one is on the way and my car should be fixed within two days (hopefully).
My symptoms were different from yours, though. Your car would crank, mine made no sound at all when the key was turned. If it cranks, then I wouldn't think it's the ignition. I'd think weak starter motor, or fuel or spark problem. Anyway, good luck with it.
Drew S.
