post alignment issues...
thanks for any help... josh
That said, did you make sure to use hubcentric rings, if your wheels came with them? Check the lugnuts make sure they are all tightened appropriately...make sure all 5 have roughly equal pressure applied to them.
Beyond that, im not sure, wish i could give more advice.
Cheers,
What are the chances that 1 tire is actually bad? What does it even mean if a tire is "bad"?
Did you corner balance the car also? For the least part, make sure your fender height matches left to right. Lower on the right side will make it pull to that side.
Check your brakes also to make sure none are binding.
Left Front:
Before - +4.50
After - +4.50
Right Front:
Before - +4.70
After - +4.90
