Proactive coil pack replacement?
I know it can go bad but do they get weak after 25 years?
A4 Coil Pack
This was a catastrophic failure of sorts, causing a surge that blew the ECU fuse. Luckily, all was well after the coil pack replacement.
From what I hear, what will really strain the coilpack is if the plugs & wires are in poor condition which causes it to work harder. So I'd start by giving your plugs & wires a lookover, maybe check the resistance values & make sure they are in spec before sprinkling parts around.
If you are feeling ambitious, you could also do the coil on plug conversion and eliminate that style pack entirely.
I keep my plugs and ignition wires maintained but sounds like picking up a Bremi pack for ~$100 is a good insurance policy.
I don't think a conversion kit is available for the 30V and the ones out there are 5x more expensive than the original part.
There is a list of parts that can cause engine shutdown or risk of cascading failures so if you want running reliability from the 2.8 then consider replacing items such as:
Coil pack and plug wires
Fuel Pump
Fuel Pump Relay
Crankshaft Position Sensor
Timing Belt Kit including water pump and thermostat
Coolant Expansion Tank (turns brown and develops cracks with age)
Coolant Temp Sensor
PCV components
Accessory Belt and roller / tensioner
And more depending how far you want to go
