Problem with lights
Old Nov 2, 2007 | 09:05 AM
D2's 90s's Avatar
New Member
Default Problem with lights
I drove for 12 hours straight (just stoping for gas) and the last time i put on my blinkers my headlights turned off, i turned off my blinker and the headlights went back on. i stopped for 2 hours then drove 12 more, when i got to my destination i tried my head light and they didn't work. I checked the fuse and it's fine, then i went to autozone and he told me to try the headlights, so i changed the drivers side and even though the bulb looked fine the lights (both) turned on with a new bulb in the drivers side. then later that day i tried them again no more headlights! I can't figure out what's causing the problem any sugestions?
it's a 96 a4... not the car in the pic
Old Nov 2, 2007 | 09:13 AM
Joey T
Guest
Posts: n/a
Try the FAQ?
Old Nov 2, 2007 | 09:54 AM
Togglehead's Avatar
There is also a tech writeup on how to fix this. I just did it.
Old Nov 2, 2007 | 10:01 AM
Joey T
Guest
Posts: n/a
Default That guy who wrote that is *awesome*.
Good lookin fella, too.
Old Nov 2, 2007 | 10:33 AM
Im@wesome~ out!'s Avatar
tr00f
Old Nov 2, 2007 | 10:39 AM
JAFO's Avatar
imo it's you combination switch. it runs $120 or so
Old Nov 2, 2007 | 12:04 PM
mike in cincy's Avatar
New Member
Default Re: Problem with lights
Just replaced my combo switch (97 TQM) last week. The only difference I had versus the write-up in the FAQ was that I had 24mm nut instead of a T-50 holding the steering wheel on. You might be in the same boat with a '96. Follow the write-up as it's completely straight forward.
Old Nov 2, 2007 | 01:08 PM
JAFO's Avatar
iirc the 98.5 and up have the T-50 and a different spline.
 Michael S. Palmer
Old Nov 2, 2007 | 01:16 PM
Togglehead's Avatar
Ah..youre right...mine was a triple square. I have a 98.5.
Old Nov 2, 2007 | 11:51 PM
D2's 90s's Avatar
New Member
hey thanks with the help everyone... yeah i started tearing it all apart, when i realized i needed a bigger socket... bought a 22 and a 23... so close but yeah, once i got a 24 it worked thanks a lot guys !!!
