problem with tiptronic a4
Old Apr 13, 2006 | 09:44 PM
audi1.8t4life's Avatar
New Member
Default problem with tiptronic a4
i have a 1.8t a4 and i have a neuspeed pchip with a GIAC tip chip and everytime im in fifth gear and im goin 110 or 115 and i punch the throttle the tranny starts shifting back and forth between 4 and 5th gear?
some one help me out with a resolution...at first i thought it was the pchip so then i got the tip chip so now i dont know what to do....
help me out this is yager...
Old Apr 13, 2006 | 10:29 PM
ImAwesome's Avatar
Senior Member
Default that's built in.. if you floor it... it automatically downshifts for you..
but then your revs get to high.. so it shifts to fifth... but you still have your foot to the floor so it goes to fourth... but then your revs get to high.. so it shifts to fifth... but you still have your foot to the floor so it goes to fourth... but then your revs get to high.. so it shifts to fifth... but you still have your foot to the floor so it goes to fourth... but then your revs get to high.. so it shifts to fifth... but you still have your foot to the floor so it goes to fourth... but then your revs get to high.. so it shifts to fifth... but you still have your foot to the floor so it goes to fourth...
don't punch it... slowly apply throttle and work through the gears... it's at WOT that the comp will downshift
Old Apr 13, 2006 | 11:35 PM
specialk9991's Avatar
Junior Member
Default No worries, its supposed to do that...
the feature (called kick-down) is so that you can summon higher revs to achieve the better acceleration the tranny assumes you are trying to achieve by flooring it. Its essentially there for passing situations. The transmission then realizes it cannot stay in this high-rev situation for very long without damaging (in Audi's mind) consequences, so it shifts back up.
FYI, you should try to avoid doing this very often (especially when traveling above 100 miles per hour), as it will wear your transmission and motor drastically.
Old Apr 14, 2006 | 05:15 AM
Durrrrty Dufour's Avatar
Default why are you going 110 or 115 in the first place?
if you arent on the track stop putting other peoples' lives in danger
</>rant
on a helpful topic, Ill say the same as the other guys. The tip is supposed to down shift to help you with pick up.
Old Apr 14, 2006 | 09:30 AM
TJHUB's Avatar
Junior Member
Default If you have a nDBW car, there is a mechanical switch under your gas pedal. It activates the
kick-down feature for the Tiptronic. This switch resides PAST full throttle (yes, I have verified this). If you press the throttle down slowly you will be able to feel the switch's resistance. With practice, you can easily avoid pressing the switch while still getting WOT.
BTW: Yeah, don't go that fast on the streets. NOT COOL!
Avants
11
Aug 25, 2006 08:07 PM
DaveyKid
Jun 5, 2004 08:42 PM
alfabutt
Jul 19, 2003 01:26 PM
chzball
Dec 13, 2002 11:43 AM
zuzubird1
Jan 28, 2002 11:12 AM
