Promising Turbo Kit?
Package Includes:
1 X T04E Turbocharger
1 X Stainless Steel Turbo Manifold
1 X 35mm/38mm Wastegate with Spring
1 X Braided Oil Feed Line
1 X 5-Bolts Downpipe Flange
1 X Aluminum Intercooler
1 X 8-Piece Piping Set
1 X Aluminum Blow Off Valve
1 X Aluminum 2.5" Flange Pipe
1 X 3" Round Air Filter
1 X Turbo Boost Controller
1 X Box Style Turbo Timer
1 X Fuel Pressure Regulator
1 X Braided Oil Return Drain Line
1 X Turbo Boost Gauge
1 X Oil Temperature Gauge
1 X Water Temperature Gauge
1 X Voltage Stabilizer
1 X Copper Ground Wire Kit
1 X Oil Catch Tank
1 X Oil Filter Relocation and Oil Line Kits
1 X 10-Row 10 AN Oil Cooler
Hardware, such as Gasket(s) and Bolt(s), if Shown in the Picture Above
8-Piece Piping Set Includes:
2 X 180 Degree U-Pipe
2 X 90 Degree Pipe
2 X 45 Degree Pipe
2 X Straight Pipe
Application:
97-06 Audi A4
(Base/ Avant/ Cabriolet)
97-06 Audi A4 Quattro
98-05 Volkswagen Passat
(GL/ GLX/ GLS)
(ALL Models Above with an I4 1.8L DOHC Turbocharged Engine ONLY)
*No instruction included and Modification such as welding may be needed
Professional Installation is highly recommended
*Items Color May Vary Depends on Inventory
*The Installed Kit Picture (Right Bottom Corner) is a sample only, may not same as the one you purchase
High Compression/ Boosting T04E Turbocharger
Specifics and Benefits:
Capable of Boosting Horse Power up to 300+ BHP
High Quality Material, Cast Housing with Durable Steel
Exhaust (Turbo Manifold) Flange: Standard T3/ T4 4-Bolt
Exhaust (Downpipe) Flange: Standard T3 5-Bolt
Intake Inlet/ Outlet: 3.00"/ 2.00"
Compressor:
Trim: 55
A/R: .50
Inducer: 50.50
Exducer: 76.00
Turbine:
Trim: 73
A/R: .63
Inducer: 65.50
Exducer: 55.90
Stainless Steel Exhaust Tubro Manifold
Features and Benefits:
High Performance Tubular Turbo Racing Design
Made of High Quality T-304 Polished Stainless Steel Alloy Material for Strength and Durability
Tubular Design to Ensure Equivalent Exhaust Flow Rate from each Cylinder
Computerized Mandrel-Bended to Maximize Air Flow Smoothness
TIG Welded CNC Machined Flange for Resistance against Cracking and Wearing
Increase Engine Exhaust Output and Efficiency
38mm/ 35mm External Wastegate Port and Flange Included
Standard T3/ T4 (T03/ T04) Configuration Outlet
35mm/ 38mm Wastegate with Spring
High Strength Cast Steel Body with Steel Head
Comes with 8-PSI Spring Installed
35mm or 38mm Wastegate Dump Pipe Flange
Stainless Steel Braided Oil Feed Line
Made of High Quality Stainless Steel Hose
Stainless Steel Braided Hose
10AN Fittings Anodized Ends
Inner Diameter: 0.25"
Length: 36.00"
1/8 NPT Fittings Natural Polish Finish
5-Bolts Flange
Made of High Quality T-304 Mild Steel Durable Material
Construction Prevents Warping Due To High Heat
0.50" Thickness Flange
Made of High Quality T-6061 Aluminum Durable Material
Helps Reducing Engine Inlet Temperature
High Performance Bar and Plate Turbo Racing Design
Allow More Horsepower at the Same Boost Level and Even More Power at the Higher Boost Level
Intercooler Size: 31.00" (L) X 12.00" (H) X 3.25"(W)
Core Size: 24.00" (L) X 12.00" (H) X 3.25"(W)
Inlet/ Outlet : 2.25"/ 2.25”
Inlet/ Outlet Inner Diameter: 3.00"/3.00”
8-Piece Aluminum Piping Kit
Made of High quality T-6061 Lightweight Aluminum Piping
Increase 65% Air Flow Comparing with other Standard Piping
3.00" Piping Diameter
Polished Surface Finish
Billet Aluminum, Anodized Finish Body
Draw In Surrounding Air and Release a Unique Discharge Sound
40mm, Hard-Anodized Valve for Increased Airflow
High-Quality Diaphragm and Short Stroke Significantly Increase Response
Dual Spring System Promoted Response and Allows for High Boost Pressures
2 Bolt Mounting Design
Holds Up to 30 PSI Boost Pressure
Aggressive JDM Discharge Sound
Fits Type-S/Type-RS Dump Pipe Flange
Construction Prevents Warping due To High Heat
Made of High Quality T-6061 Aluminum, Lightweight Design
2.50" Pipe Size
3” Round Tapered Cone Air Filter
Made of Reinforced Material and Covered with Chromed Finish for Lightweight and Durability
3" Filter Inlet, 3" Inner Diameter Pipe, 6" Overall Height
Performance: Improves Up to 95% Filtration Efficiency
Micro Cotton Gauze Type Filter Material, Washable with Water or Soap, and Reusable
Worm Gear C-Clamp Included
For Intakes or Turbo Usages
CNC Machined Aluminum Anodized Finish Body
1-30 PSI Adjustable
Allows the vehicle to idle the engine, for the timed period, with the ignition key removed
Universal for all manual & automatic transmission vehicles both turbo-charged or non turbo-charged.
Auto Mode - Precise calculation of cool down period to ensure proper cool down of turbo-charged engine.
Digital display - Allowing you to see during day & night time
Adjustable from (1-15) psi to (140) maximum fuel pump capacity
Fuel pressure regulator can deliver vehicles’ highest performance, with long life and high reliable operation
Adjustable fuel pressure regulator with 1:1 ratio
CNC machined light weight
Comes with hose and bolts install kit
Stainless Steel Braided Oil Return Drain Line
Made of high quality CNC Steel & Aluminum
Improve turbo performance by draining excessive oil, and can recycle oil back to the turbo
10AN Fittings, 17" Length
Inner Diameter: 0.50"
2" Smoke-Tinted Turbo Boost Gauge
Smoke TINT Screen
Red LED illuminated needle
2” Gauge Diameter
Mounting kit and hardware included
2" Smoke-Tinted Oil Temperature Gauge
Smoke TINT Screen
Measures from 0 - 150 Degree Celsius
2” Gauge Diameter
2" Smoke-Tinted Water Temperature Gauge
Smoke TINT Screen
Measures Water Temperature from 0 - 150 Degree Celsius
2” Gauge Diameter
Voltage Stabilizer
Improves Ignition Flow and Strengthens Starting Power
Stabilizes Voltage, Improves Engine Performance
Better Throttle Response
Improve Audio Quality
Improve Fuel Efficiency
Increase Headlight Brightness
Virtually Increases Horse Power and Torque
Longer Battery Life Time
Specially Designed with High Water and Heat Resistance
High Conductivity Copper Ground Wire
Made with High Quality Copper Material for Maximum Conductivity
High Quality Plastic Wrapped for Preventing Power Loss, Lowering any Electrical Resistance
i.e.Increase the Effectiveness of the Entire Electronic System.
Design for Centralizing the Grounding Point of the Electrical Circuit of Vehicles.
Essential especially for Any Vehicle with Engine Swaps since Grounding Tends to be an Issue with Performance Modifications.
1 X 25.00" (Overall Length) Ground Wire; with 24.50" (Distance of the 2 Centers of Connection Terminals)
2 X 33.00" (Overall Length) Ground Wire; with 32.50" (Distance of the 2 Centers of Connection Terminals)
2 X 40.50" (Overall Length) Ground Wire; with 40.00" (Distance of the 2 Centers of Connection Terminals)
Mounting Kits Included
Oil Catch Tank
TIG Welded T-6061 Light-Weight Aluminum Construction
Light-Weight Filter Tank Design for Racing Applications
Clear Tube Indicator for Easy Visual of Checking if the Tank is Full
Ensure Better Mileage, Better Performance and Preserve Engine Life
Catch Oil and Sludge to Save the Life of the Engine
Made of High Quality Lightweight Aluminum with CNC Laser Cut
Allows Installation of Larger Oil Filter
Increases Engine Oil Capacity Available; thus, Enhances Oil Lubrication and Protection of Engines
Oil Filter Relocation for Easier Access and Oil Change; a Must for Hard-To-Reach Oil Filters
10-AN Male Fitting and 0.875” x 12.125” Bolt Pattern
Quality Stainless Steel Braided for Strong Reinforcement of Strength and Durability
Inner Hose Material: CPE Synthetic Material Tubing
Maximized Resistance to Heat, Corrosion and Abrasion
Woven (Mechanism) Construction for Enhancing Flexibility
Universal 10-Row 10 AN Oil Cooler
Usable to Cool Down Engine Oil, Transmission, and Rear-Differentials
Made with High Quality T-6061 Aluminum
Powder-Coated and Oxidized for Durability and Protection
Excellent for Modified Street Vehicles, which are Driven Hardly with Minimal Track Use
Potentially Reduces Oil Temperature up to 50°F
Helps Reducing Coolant Temperature
Extends Engine Life
Overall Size: 13.50" x 6.50" x 2.00"
Core Size: 9.00" x 5.50" x 2.00"
Inlet / Outlet Size: 10 AN
Looking for feedbacks, comments, inputs, etc. Thanks much!!!
EDIT: BTW, I am now living in the Bay Area. So if anyone can give me an input as to who can install and tune this kit, please give me a shout out! Thanks again!!!
