question
Old Feb 20, 2001 | 08:32 AM
oldkenobi's Avatar
Junior Member
Default question
This has probably been talked about before but, how do you take off the front liscense plate bracket and what is under it if you do. does the bumper require painting, holes to be filled?
Thanks
Silver '99 A4 Avant
Old Feb 20, 2001 | 08:34 AM
WJM's Avatar
WJM
Tech Guru
3 large holes
Old Feb 20, 2001 | 08:36 AM
Ron_C's Avatar
Default what WJM means is...
three <B><I><U>LARGE</U></B></I> holes!!
Old Feb 20, 2001 | 08:39 AM
xr4tic's Avatar
Default Or 3 large holes, and two small ones....
If the previous owner used screws to hold the plate that were too long
Old Feb 20, 2001 | 08:58 AM
audimods's Avatar
yes, i can relate to that. I ended up sanding the parts that stick up and put painted plugs in.
Old Feb 20, 2001 | 10:24 AM
DustysA4's Avatar
Default Re: question
To take off the front plate just take off the liscense plate, then you should see what there is. Basically just undue every bolt you see and you will eventually get the entire mounting bracket.
Under the bracket is three holes that will need to be plugged. I haven't taken my bracket off cause it is illegal where I live, but I've heard people that have say they went to their Audi dealer to get the plugs and they refused....so they went to the Porsche dealer(next door where I live) and asked and they didn't even charge them. They were like, we didn't make it so we don't care. Hope this helps.
Old Feb 20, 2001 | 11:30 AM
oldkenobi's Avatar
Junior Member
Default Thanks
Thanks much, that helps
GBadger
Q5/SQ5 MKI (8R) Discussion
Jan 2, 2014 05:16 PM
Jim Germany
A4 (B8 Platform) Discussion
May 11, 2008 10:16 AM
FSC
RS4 (B7 Platform) Discussion
Jan 4, 2007 11:08 PM
Richard (TTustin, CA)
Jan 1, 2001 04:49 PM
John
Dec 21, 1998 09:44 AM
