question about engine temp ...
I'd love to hear if anyone has any othe suggestions.
Thank,
Frank
Make sure the engine is cool and you loosen the coolant tank cap before taking this out or else you'll cause a mini-geyser when replacing this part. There is a little horseshoe clip you you slide off to get the sensor out.
Here's where it should be located on a 1.8T
It's the blue module.
<img src="http://pictureposter.audiworld.com/1308/coolantsens1.jpg">
<img src="http://pictureposter.audiworld.com/1308/coolantsens2.jpg">
Since the location is higher, you will only lose a little coolant. You can just add some distilled water to the tank. I lost very little and wound up adding a half cup of distilled water when I replaced mine.
Mine went at 65k. It has been known to fail around our range. Your car will still run fine.
