questions on intakes
Old Mar 26, 2001 | 11:50 AM
audidood's Avatar
Default questions on intakes
1. what is the difference in power between a stock air box, a "modded" air box, and a cone?
2. which of the above are available for the 96 2.8q?
Old Mar 26, 2001 | 12:12 PM
maaliish's Avatar
Default Get the cone, you will not regred it!
I got one (made by TAP) for my 97 12V and it sounds amazing.
Its nice and quite stock level when you drive normally, but when you punch it, the engine just roars. Under medium stress, the engine sounds like a V8 around 3000 rpm (no joke, my buddy has a 5.0 and he really liked the sound). Under heavy load, the engine sings a nice tune untill about 4700 rpm and then the sound becomes more intence almost like on vtec cars at the switch point, but deeper/bassier. I aboslutely love this intake.
There is a definate power increase and my G-Tech shows constant improvements of around .3 seconds, but the best thing about this intake is the sound.
We do not have to worry about hot, engine bay air, because our engine bays do not heat up as much as 1.8T does. I will test the intake temps as soon as I get the VAG tool (thanks Ed) and then if there is a difference, I will fabricate some sort of shield, which should not be that hard to do.
The intake is only 120 from TAP and I definately recommend it.
Old Mar 26, 2001 | 12:26 PM
WYSIWYG's Avatar
if you just want to try it out, make your own(no regrets). just dont get the U shaped 'intake kits'
Old Mar 26, 2001 | 12:31 PM
audidood's Avatar
fits the 96 2.8s also?
Old Mar 26, 2001 | 12:36 PM
WYSIWYG's Avatar
Default here's some old pics. current setup is sealed with aluminum sheilding on top
<b><font color=red>again there is a cover on top of the whole thing </font></b>
<img src="http://pictureposter.audiworld.com/12079/intake1.jpg">
<img src="http://pictureposter.audiworld.com/12079/intake2.jpg">
Old Mar 26, 2001 | 12:40 PM
audidood's Avatar
cool!
Old Mar 26, 2001 | 12:44 PM
maaliish's Avatar
Default I think so, check here:
<ul><li><a href="http://www.tap1.com">www.tap1.com</a></li></ul>
Old Mar 26, 2001 | 12:47 PM
maaliish's Avatar
This one is for 1.8T, so yours will look different, but the idea is the same.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 26, 2001 | 12:51 PM
QuattroRocket's Avatar
Did u just slide the cone onto the MAF from the air box and the MAF into the duct tube?
Old Mar 26, 2001 | 12:55 PM
audidood's Avatar
shweet ... i may just have to order me one!
