Quick ?
Old Mar 31, 2008 | 01:48 PM
duburban's Avatar
New Member
Default Quick ?
I'm going to put my avant into service position for the first time tomorrow and i just am not clear about the rods that hold the radiator support. Can i use the 2 allen bolts that come out of the bottom of the bumper?
Old Mar 31, 2008 | 02:15 PM
4Rings::G2 boosted::'s Avatar
Banned
Default Those bolts only hold on the bumper skin, which has to be removed
Under the bumper you'll find 4 bolts per side that hold the bumper supports to the frame. You'll have to loosen/remove those to put the radiator support into the service position.
Old Mar 31, 2008 | 02:32 PM
2.0GT35's Avatar
Member
Default Corrections
the 2 bolts hold the bumper support onto the bumper shocks, I also think you mean "behind the bumper" not under. Well unless your car is always standing on its rear bumper, then you would be right.
BTW its 3 bolts that hold the shock to the frame, there is usually one spot that doesn't have a bolt which is used for the "service" position of the raditor support.
Old Mar 31, 2008 | 03:35 PM
Bryans12v's Avatar
Default Yeap! also...
You really dont need to use the special VW tool to do it. I work at a dealer and most of the tech's just use long 8mm bolts.
The thread pitch is 8x1.25 and the longer the better (120mm+) should work fine. You can most likely pick them up at a decent hardware storeor lowes.
Old Mar 31, 2008 | 05:06 PM
Hillbilly's Avatar
Member
Default Just buy a stick of allthread. cheap, and you can cut it to the size you want.
doesn't have to be tight, just thread it in by hand.
Old Mar 31, 2008 | 05:17 PM
duburban's Avatar
New Member
Default right right
Thanks for the help. I know there are 3 bolts holding the shocks to the frame, But last time i took my bumper off i took 2 allen bolts out, from under (if facing the bolt head). I heard that you could use these to slide the bumper out onto. Guess these aren't the them though. Thanks for the thread size and pitch, perfect! I would be so in debt to my local guy if it weren't for yall. 175k is an important time for my Avants maturation! Might be old but at least its a milf.
Old Mar 31, 2008 | 05:27 PM
Hillbilly's Avatar
Member
Default you said it!
this sit has become my automotive bible. If it were to ever(God forbid) shutdown, I would probably sell my car. lol.
aannnnd MILF = FTW!
Old Mar 31, 2008 | 07:17 PM
duburban's Avatar
New Member
Default Re: you said it!
i hear you man, it would be time for that honda accord that the economical side of me longs for.
Old Mar 31, 2008 | 07:44 PM
Hillbilly's Avatar
Member
agreed, but I would go with a TL over an Accord any day. Although the '08's are quite intriguing.
Old Apr 1, 2008 | 06:04 AM
northof49(+1+1)'s Avatar
yes
Shanef1014
Feb 18, 2016 09:44 AM
duncanm
22
Oct 24, 2007 08:45 AM
lyonelll
Mar 13, 2005 09:10 AM
shadyraven
9
Feb 8, 2004 06:03 PM
mrwho13
Mar 25, 2002 05:12 AM
