quick help please
Old May 31, 2004 | 12:31 PM
Al Nuggs's Avatar
New Member
Default quick help please
Hi
Just had to jump start the car. dead batery from interior light being on for the last 2 days. I drove around to block a few times to help charge up the batery and the car is a little slugish. and looking at the boost gauge the idle is at 19 vacume normally it is at 23 vacume.
do I need to align the throtle body?
if so how??
thanks for the quck help, the car is outside ideling need to get back to it
Old May 31, 2004 | 12:35 PM
slimj's Avatar
Default What year is it?
If you turn the key over, without starting it, it should automatically align the TB. Just let it sit for about 5 minutes and then turn it over. It might depend on the year though.
Old May 31, 2004 | 12:37 PM
Al Nuggs's Avatar
New Member
Re: What year is it?...its a 2001
Old May 31, 2004 | 12:46 PM
slimj's Avatar
It should automatically align it on an 01
Old May 31, 2004 | 12:48 PM
Al Nuggs's Avatar
New Member
Default Re: It should automatically align it on an 01
thanks
Old May 31, 2004 | 01:07 PM
Al Nuggs's Avatar
New Member
Default so I just took it for another test drive around the block...long
after leting it sit in the on position, not running for 5 minitues.
and on the test drive i discovered the one touch power windowes were not working granted the windows would go down and up but not one touch. however when I got back to my parking spot the one touch was functining and then I tried the lift switch function on the sun roof and it went up a little and I press a few more times and the the sun roof was working properly again.
its as if the car had to learn these functions again.
Can any one explain this???
Old May 31, 2004 | 01:14 PM
slimj's Avatar
Default Yeah that's what happens
When you disconnect the battery, the functions all go back to default. Default for the windows is for the one touch to be disabled.
Just hold the down position for a few seconds after it's all the way down, and then release. Hold the up position for a few seconds after it's all the way up, and then release. That should reset the one touch. You may need to do it for all windows, and the sunroof.
How is it driving now?
Old May 31, 2004 | 01:20 PM
Al Nuggs's Avatar
New Member
Default I will try the the re-teach the functions
the car was peaking 18psi (giac) but it was still a little slugish on the low end. probably a little heat soaked from all that time ideling to recharge the batery
thanks for all the help!!
 Michael S. Palmer
Old May 31, 2004 | 01:39 PM
slimj's Avatar
Default It's kind of odd, I would expect it to be
a little peppier after reseting the throttle body, but it is possible that it got a little too warm. Is it hotter outside than usual? That might decrease boost.
tuna138
Dec 5, 2013 11:41 AM
spikie1.8T
Mar 23, 2008 09:34 AM
green88'90Q
May 27, 2007 09:40 PM
Audigirl2004
Feb 24, 2004 12:52 PM
FNKYnoS4
May 20, 2001 08:07 AM
