quick HID question...
Old Sep 16, 2006 | 03:20 PM
nova24's Avatar
New Member
Default quick HID question...
i have been looking at a couple of HID kits, and they look the same, except for a couple of differences. one kit plugs into the plug, goes to ballast and then out to the bulb. the other one does the same thing, except that you have to run a wire to the battery that also has a relay on it. what is the differences between the 2 kits and which one is better. i like the one that is just plug and play. any comments will help. thanks.
Old Sep 16, 2006 | 03:29 PM
ChooChooNongNongHead's Avatar
Default either way you should run a separate ground to the ballast. If you use the OEM wire
you may eventually have a problem where one or both of the lights will not ignite. No big deal, just a new wire going to direct ground close to the ballast.
The Stig
Oct 8, 2009 07:44 AM
Jesster
Oct 24, 2006 04:06 PM
caveman98
19
May 5, 2005 04:04 AM
turbotol
Dec 12, 2002 11:39 PM
Absltgreek (Mafia)
Aug 9, 2002 11:29 AM
