quick question...
Old Jun 11, 2002 | 03:07 PM
Noni S4's Avatar
New Member
Default quick question...
i just bought a set of s4 headlight from a buddy of mine that just got a set of ecodes and i have a 98 a4...what do i need to have/do to make them work properly. or will they even work? TIA
Old Jun 11, 2002 | 03:08 PM
coocoomike's Avatar
wiring harness, and you need a tool to trim the fender
Old Jun 11, 2002 | 03:10 PM
Noni S4's Avatar
New Member
where would the best place to buy the harness...how? much?
Old Jun 11, 2002 | 03:15 PM
Phil type 951's Avatar
Default Re: awe. prepair to get ripped! $40 piece of plastic
http://www.awe-tuning.com/pages/shared/part_detail.cfm?PMaI=1&PMoI=1&PEI=2&PP =a4_18t_exterior.cfm&PPT=Exterior&IL=A4Pro jectorLights
http://members.aol.com/drewinva/audi/euro_conversion.html
enjoy
Old Jun 11, 2002 | 03:20 PM
Bill In SoCal's Avatar
Member
Default Do this for free.
<img src="http://pictureposter.audiworld.com/12026/p9010565.jpg">
Old Jun 11, 2002 | 03:22 PM
simply J's Avatar
Senior Member
Default Oh they work... I have S4 headlights in my 97 A4
you have to trim the fender, and you can use your old harness... you just have to cut a circular hole for the plug and seal up the old hole. You also have to seal the hole for the ballast underneath and rig up some kind of way to attach the inner housing in place of the leveling motor. If you need any info e-mail me and check my pic poster for some pics. Good luck
Old Jun 11, 2002 | 03:32 PM
Re: ok thats another option what did you do excatily?
Old Jun 11, 2002 | 03:43 PM
Member
Default Re: ok thats another option what did you do excatily?
matched the old round harness wires to the appropriate pins on the projector housing.
Soldered clips to the ends of the wires.
Pushed them on.
Filled around with Silicon to seal.
And the black stuff you see is heat shrink wrap before I shrunk it. That stuff wraps tightly around the wires to protect them.
With this method no cutting/splicing or any modification of any kind needs to occur on the cars factory wiring harness
 Michael S. Palmer
Old Jun 11, 2002 | 04:07 PM
Default Re: cool, whatever works! I would rather have the
right piece even if it is a rip!
Old Jun 11, 2002 | 04:12 PM
Member
Default I guess if it makes you feel better.
I'd rather use a little ingenuity then paying $40 for a piece of plastic.
