Quick question plz help
I did a continuity/resistance check from the TCM and everything seemed right. Could the sensor still be bad?
Maybe I am answering my own question here, but if I can see a value pop up intermittently using vagcom message blocks does that mean the signal is poor because of the sensor? Or could it be from a bad TCM(mine is not water logged)
Maybe even it could be an ungrounded transmission?
I am getting a p0716 code.
Any suggestion will help.
I am leaning towards replacing the g182, but I want to be sure before I do.
I already cleaned the wiring harness connection and checked the wires, My next step is to look for a missing ground wire on the transmission. Anyone know where that might be???
That last question is the quick one
