Radar Detector --- Wireless??? Hidden???
Old Oct 10, 2003 | 06:03 AM
jrmtch's Avatar
New Member
Default Radar Detector --- Wireless??? Hidden???
My A4 UltraSport is on the ship right now.
Anyone have any radar detector suggestions???
I don't want the wire hanging down.
Anyone using a wireless radar detector or
have a descretely mounted setup???
Also, any suggestions on tint %???
Thanks
Old Oct 10, 2003 | 06:05 AM
audiski's Avatar
Member
I've seen a few V1's above the rear view mirror. Looks dope.
Old Oct 10, 2003 | 06:17 AM
KenK in TX's Avatar
Default For a hidden install, go remote - Bel or Escort.
My Bel 975R control panel is in the cupholder...
<img src="http://pictureposter.audiworld.com/10477/16x12_975r_panel.jpg">
...and the horn is mounted behind the grill.
<img src="http://pictureposter.audiworld.com/10477/16x12_975r_antenna.jpg">
You can pick these up for $350, and there's a $50 rebate for "professional" install, which you can easily fudge a reciept for.
Old Oct 10, 2003 | 06:19 AM
Wir fahr'n auf der Autobahn's Avatar
hardwire a V1 or 8500... cordless detectors are useless
Old Oct 10, 2003 | 06:20 AM
Delta-9's Avatar
If you go to the V1 website it explains why cordless detectors are teh suck.
Old Oct 10, 2003 | 06:23 AM
RKA's Avatar
RKA
AudiWorld Uber User
Default You really need to spend some time searching the forums.
This is a commonly addressed topic...almost as common as "which oil should I use". Just to give you a little background...
Valentine One (aka "V1") - one of the very best. It's a windshield mounted unit, but many people hardwire it to their cars, and run the powerwires out of sight.
Passport 8500 - also a top contender, often mentioned. Windshield mounted as well, can be hardwired with power cords run out of sight.
Remote systems usually compromise performance with radar range, due to the orientation of the front radar antenna (down low, by the ground). K40 is one of the more popular ones. Passport makes one too.
Cordless units usually compromise performance. Passport released the Solo2, which one person on the S4 forum responded favorably to. If you were to buy a cordless model, this is the only one I would consider...still, I remain suspicious of cordless units, as they generally make performance tradeoffs to get decent battery life.
Laser jammers - increasingly becoming necessary. Passport, Blinder, and Lidatek make units that are reported to work well. See www.speedzones.com for more info.
Old Oct 10, 2003 | 06:28 AM
SCd_Walter's Avatar
Member
Default I like that, how do those perform? Do they have rear sensors or only front?
Most radar threats come from the front anyway, does the gril obstruct it a lot?
Any links to dealers?
Old Oct 10, 2003 | 06:39 AM
kennyc's Avatar
Default mucho money.
You think V1 is expensive until you check out Those remote radar detectors.
I hardwired a V1 and put it on top of my rear view mirror. I had to mount my mirror upside down in order to get enough room to do so.
<img src="http://pictureposter.audiworld.com/14019/v1-01.jpg">
In addition, I added a blinder laser jammer to the front bumper.
<a href="https://forums.audiworld.com/a4/msgs/1528399.phtml">Write up</a>
All these probably will cost less than the Bel or Escort remote units.
Old Oct 10, 2003 | 07:39 AM
Zodiak's Avatar
K40 all the way. the sensors are installed in the front grill. and the display in the guage cluster
Old Oct 10, 2003 | 07:58 AM
chipstar-32's Avatar
Elder Member
Default dont go wireless
get a passport 8500 or a v1 and hardwire it in
