Rear Suspension Creaking
Old Oct 8, 2003 | 07:03 PM
CTMechE's Avatar
Default Rear Suspension Creaking
I've got a 1999.5 2.8Q (non-sport suspension), and lately there's been some creaking from the rear suspension on both sides. I'm thinking it might be the sway bar bushings, because it's not particularly loud, and only seems to happen when there's decent suspension compression. Small bumps don't do this. It's pretty much equal noise from both sides. I'm hoping it's not the shocks, though. The tricky part is that it doesn't happen all the time, and seems to change with the weather. I'm in CT, and we get some rather large humidity and temperature fluctuations this time of year, but the noise is starting to happen more frequently, and it's bothering me. It's definitely not driveline or brakes. Anyone have suggestions/prior experience on what this might be, and recommendations on what to do about it?
Old Oct 8, 2003 | 07:06 PM
InphoSys's Avatar
New Member
Default Re: Rear Suspension Creaking
That sounds like what I had before Audi replaced my upper control arms on both sides at 75K miles.
Good luck.
Old Oct 8, 2003 | 07:57 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default The cheapest solution is to follow your hunch with the swaybar
bushings. Get some white lithium grease, put the car up on jackstands, remove the brackets and bushings, spray them down, reassemble, and go for a spin.
Old Oct 9, 2003 | 08:19 AM
Pat's Avatar
Pat
Default If it is the bushings, put some zyrk (sp?) fitting on the bushings so you can regrease easily.
I did zyrks a couple weeks ago, but have been too lazy to buy a grease gun so far.
KidoS4
Jan 6, 2008 03:31 PM
Willco
Jun 19, 2006 06:54 PM
Shep 1.8T
May 4, 2005 03:27 PM
ULuvItBch
Feb 26, 2004 08:33 AM
jaystizo
Mar 21, 2003 07:33 AM
