Remote starter?
I assume i can use automatic starter as long as i rember to leave her in neutral right?
Example:
You pull into your driveway, as you get ready to turn off your car, you put it in neutral, and then press two buttons on the key fob. Then you turn the key to the off position, but your car will still be running. Once you exit the vehicle and arm the alarm, the car will turn off by itself. They do this to ensure that you cannot leave the car in gear, because if you did the obove with the car in gear, when you got out of the car it would die. SO...this guarantees that your car is in neutral when you leave, and when you activate the remote start the next morning your car will still be in neutral.
It seems like alot to do just for remote starting your car, but after i watched a friend remote start his mustang into his garage wall (not a clifford alar), it was an easy decision for me. PLus you will never have to doubt yourself about wether or not you left your car in gear.
Another up side: When you get out of your car and arm it, you can program the alarm to keep the car running for turbo cool down. The alarm will arm, but the vehicle can stay running for as long as your program it to.
I just told him hes a moron, and should never assume, especialy in the automotive repair industry, thats how people get hurt and property gets damaged, and that i wont ever be taking my car back there again.
must have felt good coming from a 21 year old to the 50-somthing year old "expert"
I went somewhere else after replacing the PCV system and passed flawlessly.
