repeat maf fails
Old Mar 1, 2010 | 07:03 PM
kpnels's Avatar
Default repeat maf fails
2000 a4 1.8t maf keeps going bad 1137 and 1128 codes.new mafs last for 1500-2000 mi.what the #%&*&^! please help
Old Mar 1, 2010 | 07:04 PM
RallyVermont's Avatar
Mr Mc Feely
You don't have a K&N filter do you? check all wires around the maf for fraying.
Old Mar 1, 2010 | 07:07 PM
kpnels's Avatar
stock filter,wires seem good
Old Mar 1, 2010 | 08:16 PM
Tuppidsay's Avatar
at the same time? 1137 is rich at idle only and 1128 is lean all the time. Kinda odd. I've been a mechanic for 6 years and have never seen a rich code cause by a maf sensor. it's technically possible but unlikely from my experience.
Old Mar 7, 2010 | 04:15 PM
kpnels's Avatar
not at the same time-1137 first then 1128 shouldn't maf fail code be the same?
Old Mar 8, 2010 | 01:31 AM
Tuppidsay's Avatar
Neither code is a maf sensor code. They simply state that the car's computer has to modify it's base fuel delivery rate way too much to maintain it's goal air fuel ratio. Lean code means it's adding more than 20% extra fuel and rich means it is taking more than 20% fuel out.
Old Mar 8, 2010 | 01:38 AM
Tuppidsay's Avatar
While a maf sensor is certainly a possibility. It not telling the computer how much air is going in. Other posibilities are things like vacumme leaks, clogged fuel filter, injectors, weak fuel pump, failing O2 sensors, etc. Your either getting too much air (or atleast more than the computer thinks it is) or not enough fuel.
Old Mar 8, 2010 | 06:53 PM
TopnotchA4's Avatar
Well I have a somewhat simlar issue on my 2000 A4 quattro 1.8t quattro.
The car has a p1128 (lean condition)
recentely the care idle funny at first start up, when its cold.
It sounds like a slight bog. . not drastic. .
I recentely replaced the fuel filter. . the fuel in the filter looked very dirty. It was actually more like almost black. .
Also someone asked about if this member was using a KnN air filter?
This car happens to have one, I actually cleaned it all up and reoiled it. Is the KnN a bad route?
Any feedback and/or advise would be greatly appreciated!!
Im suppose to have it emission tested by the 11th
I thought maybe the MAF was bad, the seller told me that he recently replaced it. .
pattersom
Aug 4, 2006 09:10 AM
silverTTQC
Jul 27, 2005 06:52 PM
o1A4
Sep 12, 2004 02:21 PM
PILL PUSHER
Apr 29, 2004 06:46 PM
