Replace DV to 710n
Old Dec 22, 2005 | 12:31 AM
thewatcher101's Avatar
Elder Member
Default Replace DV to 710n
I just replace the 710n dv and notice a change in boost. The max boost seems to be around 9-10psi vs. old dv which averaged around 11psi. The needle has been moving diffrently it no longer peaks as much as the old dv. Does anyone know what are the changes that should occur with a 710n dv. I am running a .8 bar that should be boosting around 11.5 psi.
Old Dec 22, 2005 | 01:09 AM
BJC::wokka wokka's Avatar
Elder Member
Default Check the hoses....
you should not see any difference in psi. You should notice difference of less lag..
Old Dec 22, 2005 | 01:11 AM
Shep 1.8T's Avatar
Member
Default how do you have it installed?
You can run it backwards, so that boost pressure doesn't hit the piston directly it hits the side of the piston. Is everything tight down there with concern to clamps and such?
Did you use a screwdriver or something along those lines to remove the old DV and possible tear some of the hose down there?
Did you verify the valve was working correctly when you installed it? ie, push the piston down with your finger, plug the vacuum hole and release the finger on the piston, and it should stay. Release the finger over the vaccum hole and it should spring shut.
The 710N is what I use and I hold 20 psi with it and much more airflow than you, I'm betting unless it was a used part that could be bad your issue is related to install.
Old Dec 22, 2005 | 05:32 AM
BSK's Avatar
BSK
i like the sig picture
Old Dec 22, 2005 | 09:29 AM
Elder Member
Thanks. 4Rings did a little photoshop to it : )
Wahhab
Audi Original "S" Cars
Jul 26, 2006 06:45 PM
Avant Sport
Apr 5, 2005 03:36 AM
Paul H. (near Annapolis, MD)
Performance and Tuning
Apr 24, 2003 08:32 AM
Chard
Jun 20, 2002 02:41 PM
MichaelTM
13
Mar 26, 2002 11:32 AM
