To replace or not to replace the flywheel...
Old Apr 6, 2006 | 07:03 AM
quattropronn's Avatar
New Member
Default To replace or not to replace the flywheel...
All, I will soon need to install a new clutch for my B5 2.8Q 5-speed. The current clutch still works just fine but will need replacement soon. I believe I will be putting in a Dual friction CenterForce clutch.
Of course, you typically want to replace or machine the current flywheel before installing a new clutch set but the dual mass flywheel I have cannot be turned. $700-800 for a new dual mass.
Must I absolutely install a new flywheel with the new clutch set or would the current one (in good shape I believe) be feasible to use??
Thanks!
Paul
Old Apr 6, 2006 | 07:05 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
If your original works fine, why even think about it? Wait till it's slipping...
Old Apr 6, 2006 | 07:07 AM
BLKPERL's Avatar
If it can be resurfaced use it, if not buy a new one
Old Apr 6, 2006 | 07:11 AM
New Member
Default Ture Kris, just thinking ahead...could begin slipping in
a few months so just want to know what to do. Once it goes though, I want to use the old flywheel - those new ones are $$$$. Thanks man.
Old Apr 6, 2006 | 07:15 AM
New Member
Default Re: If it can be resurfaced use it, if not buy a new one
Pretty sweet ride BLKPERL. I was under the impression that these dual mass wheels cannot be resurfaced? Maybe I was told wrong but several shops around town said that one or the other must be done...rather just use my stock flywheel. Thanks for the info...
Old Apr 6, 2006 | 09:58 AM
beejohn's Avatar
southbend can do it
Old Apr 6, 2006 | 11:38 AM
Stef Driver's Avatar
New Member
Default be very careful with resurfacing
I got burned by a bum resurfacing. Make sure you take it to a good machine shop and spare no expense, or just buy a new aftermarket one if you can. If it doesn't work out you might be looking at another RE & RE job to fix it plus a new flywheel anyway.
esh9953
Dec 29, 2006 07:30 AM
Jason Sowers(rs6's)
Oct 20, 2006 07:14 PM
Another Drew
Sep 5, 2004 09:29 AM
EvanUrS4
Audi Original "S" Cars
Jun 4, 2003 05:44 PM
Dirty Dingo
Feb 27, 2003 04:15 PM
