RPM's
Old Apr 19, 2007 | 02:53 PM
Boost8285's Avatar
New Member
Default RPM's
Ok...1999.5 2.8 V6....I recently had the intstrument cluster replaced because the backlight had gone dim....after the new cluster was installed, the RPM tack is now showing at least 1,000 rpms higher than it used to when driving....at 70 mph on a flat road its showing 4600.....any suggestsions? just a calibration issue? what should the rpms be doing at that speed?
Old Apr 19, 2007 | 03:04 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Where does the needle sit when its off? Is it pegged?
Old Apr 19, 2007 | 03:30 PM
JAFO's Avatar
imo it's coded for a 4 cylinder.
Old Apr 19, 2007 | 05:59 PM
BigEd's Avatar
Member
Default 2nd. Just to clarify, clusters are interchangeable between 2.8 and 1.8 cars but need
to be soft-coded appropriately. Whoever swapped the cluster should have noted the coding on the old one and entered it into the new one.
Old Apr 19, 2007 | 06:45 PM
Boost8285's Avatar
New Member
Default Re: Where does the needle sit when its off? Is it pegged?
It idles at about 1000, which is about 200 rpms higher than it used to..when i accelerate is when i see the big disparity
poseidon5
Sep 1, 2008 05:31 PM
A8-fan
Apr 23, 2004 06:17 AM
Merkin
Mar 4, 2002 12:12 PM
raffi
Mar 26, 1999 06:23 PM
Raffi
Mar 25, 1999 10:37 AM
