Running too Lean
Old May 30, 2006 | 07:57 AM
sub1427's Avatar
Default Running too Lean
Can someone tell me how to adjust my engine so it doesnt run too lean... the odb scanner said it was too lean... 1997 A4 2.8. cheers
Old May 30, 2006 | 08:01 AM
nunya's Avatar
Default Like i said in the post below... please dont back to back post someone will help you...
Check your injectors:
reseat them in the intake manifold.
maybe run some fuel injector cleaner
check fuel filter
check fuel pressure regulator
check fuel pump.
--dillon
Old May 30, 2006 | 09:02 AM
WJM's Avatar
WJM
Tech Guru
you have a leak, or pinched a line, or did something else... you need to find what is broken
Old May 31, 2006 | 03:34 AM
arussell's Avatar
Default Re: Running too Lean
Please post entire code(s). If you're seeing Long Term Fuel Trim - system too lean, I'd look for a) vacuum leak, and then b) test out your MAF.
The MAFs are notorious for this kind of failure.
dzywicki
Jan 10, 2019 04:36 PM
black97quattro
Nov 6, 2005 08:46 PM
porsches4ed (APR S3)
Oct 25, 2005 07:12 PM
in2audi
Jul 28, 2004 07:34 AM
Audi1.8T
Audi 100 / A6 (C4 Platform)
Jul 3, 2004 10:56 AM
