is rust normal for a rotor?
Old Apr 7, 2004 | 07:10 AM
audiringpwr's Avatar
Member
Default is rust normal for a rotor?
<center><img src="http://ando.web.infoseek.co.jp/mycar/MyCar/Modify/13B4/334BrakeRotorGrinding/BrakeRotorGrinding_00.jpg"></center><p>i have rust forming on on the disc itself where the pads come in contact, but on the hub part where you put the lugs in. that whole part on my rotors have rust around it. any cause for concern?
Old Apr 7, 2004 | 07:11 AM
Fastfwd's Avatar
Elder Member
This rotor looks really good compared to mine. Try winters in Quebec.
MikekiM@PureMS's Avatar
Former Vendor
Perfectly normal.
Old Apr 7, 2004 | 07:13 AM
SilverA4Fun's Avatar
Default between oxidation of the steel and moisture any rotor will rust..its
just that the pads sweep the rust of the braking surface. If wash your car, don't drive it and then look at your rotrs the next day you'll see oxidation marks
Old Apr 7, 2004 | 07:14 AM
Member
Default what would cause some rotors to rust on the hub
while others don't? btw these where oem replacements installed by an indepedent shop
Old Apr 7, 2004 | 07:18 AM
Member
Default are you refering to the rotor where the pad comes in contact?
or the hub circle section behind it?
Old Apr 7, 2004 | 07:21 AM
Former Vendor
Default They're cast iron.
Iron rusts.
Some aftermarket, and I believe the genuine rotors have a plating on them to help reduce the rust. But even over time this plating doesn't hold up, and the rotors begin to rust.
Old Apr 7, 2004 | 08:02 AM
Liam in Montreal's Avatar
Elder Member
Default ...
<img src="http://1.8t.org/~vk/misc/a4oem5spoke/IMG_1198.JPG">
 Michael S. Palmer
Old Apr 7, 2004 | 08:03 AM
Fastfwd's Avatar
Elder Member
That is NOT normal. You should drive more often.
Old Apr 7, 2004 | 09:21 AM
DougR's Avatar
Junior Member
Agree. Those wheels look impossibly clean!!
Jonatino
A4 (B9 Platform) Discussion
9
Jun 24, 2017 08:43 AM
JD797
21
May 9, 2007 01:17 PM
tristateS4
Feb 8, 2006 03:11 PM
JROO-VW
Brakes Discussion
Jul 31, 2005 10:01 AM
trifona
12
Jun 11, 2003 01:14 PM
