Short to Ground Problem
Old Sep 30, 2006 | 11:15 AM
Bboble4k's Avatar
Default Short to Ground Problem
Have a 2000 Passat V6 5spd, Tried VW Vortex, with no luck, figured it would be the as an A4 30v... Recently ran the codes, and this is what I came up with under engine.
9 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-10 - - - Intermittent
17880 - EVAP Leak Detection Pump: Short to Ground
P1472 - 35-10 - - - Intermittent
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-10 - - - Intermittent
17938 - Camshaft Timing Adjustment: Short to Ground
P1530 - 35-10 - - - Intermittent
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-10 - - - Intermittent
17923 - Intake Manifold Valve (N156): Short to Ground
P1515 - 35-10 - - - Intermittent
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 35-10 - - - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Tried searching, but didn't come up with an exact fix!
Do these components share a common ground, or connector, I imagine it is a simple fix. just wiggle fuse, or ecu connector? Or does anyone have a copy of the wiring diagram?
TIA
Old Sep 30, 2006 | 04:05 PM
David.Norton's Avatar
Default Normally I'd have a Bentley, but it isn't working just now...
anyway, that is a lot of stuff to be reading shorted to ground at once, which makes me think that the logical place for the problem would be the point in common, or alas the ECU. Just a guess though, good luck with it.
Old Nov 12, 2006 | 06:42 AM
bwrobid's Avatar
Default Re: Short to Ground Problem
i also am having the exact same problem with my 1999.5 A4 2.8 quattro 30V. i am coming up with the exact same codes. my car did this after crosing a..... SOB!, 10 inch puddle/ river of water during a rain storm last week. i am going to swap out the relay for the air pump and see if it controls the rest of the equipment.
Old Nov 14, 2006 | 12:52 PM
bwrobid's Avatar
i believe i found the problem. after tracing the wiring diagram i found that all of the trouble codes are on the same circuit. i traced mine down to a bad fuse #29(fuse in fuse box next to drivers door) coming from the fuel pump relay. other things to check in line with the circuit secondary air pump relay and fuse( in ecu box under hood drivers side). i hope this helps you.
Old Mar 26, 2012 | 10:38 AM
CARLOS8685's Avatar
Default 10 codigos de fallas con SHORT TO GROUND
UN CLIENTE TRAJO FALLANDO EL AUTO VW PASSAT 2001 V6 2.8L.... LA CHECK ENGINE PRENDIDA CON 10 CODIGOS, TODOS HABLABAN D SENSORES SHORT TO GROUND, OXIGEN SR,CAMSHAFT, INJECTOR EN FIN.. CHEQUE LOS FUSES EN A LADO DE LA PUERTA DEL DRIVER SIDE Y ENCONTRE UN FUSIBLE ABIERTO DE 30 AMPS. Q VA A LA COMPUTER.. SE LO CAMBIE Y MEJORO PERO AUN CON UN CODIGO, INJECTROR 4 SHORT TO GROUND.. CHEKE EL CBLEADO Y AL FINAL ERA EL ENGINE CONTROL MODULE....NOTA: TIENEN Q CALIBRAR LA PC PARA Q TRABAJE AL 100%....
ESPERO HABERLES HAYUDADO..
Old Mar 26, 2012 | 10:40 AM
CARLOS8685's Avatar
UN CLIENTE TRAJO FALLANDO EL AUTO VW PASSAT 2001 V6 2.8L.... LA LUZ D MOTOR PRENDIDA CON 10 CODIGOS D FALLA, TODOS HABLABAN D SENSORES CORTO A TIERRA, OXIGEN SR,CAMSHAFT, INJECTOR EN FIN.. CHEQUE LOS FUSES EN A LADO DE LA PUERTA DEL DRIVER SIDE Y ENCONTRE UN FUSIBLE ABIERTO DE 30 AMPS. Q VA A LA COMPUTER.. SE LO CAMBIE Y MEJORO PERO AUN CON UN CODIGO, INJECTROR 4 SHORT TO GROUND.. CHEKE EL CBLEADO Y AL FINAL ERA EL ENGINE CONTROL MODULE....NOTA: TIENEN Q CALIBRAR LA PC PARA Q TRABAJE AL 100%....
Old Mar 22, 2015 | 08:42 AM
Johnny Z's Avatar
Hello,
I am having the code 1472 after a plug bolt in my pre cat came out and the exhaust burned the o/2 wires I am also having variouse o/2 codes I have redone all and suspected a common thread I did chech # 29 fuse to fuel pump and it was good but after removing and reinstalling the car improved weird I never had any problems before the burn I hope it didnt permanatly effect the ECU ? Thanks for all the input Johnny
Old Dec 10, 2018 | 10:53 AM
Leo Rosa's Avatar
TENGO EL MISMO PROBLEMA CON UN PASSAT 2000..FINALMENTE ENVIE LA ECU A VERIFICAR Y ESTABA HUMEDA YA QUE TENIA EL DESAGÜE DEL FIREWALL LLENO DE OJAS..
MUCHAS GRACIAS
 Pouria Savadkouei
 Michael S. Palmer
JettaRedII
Jun 30, 2017 03:13 AM
robin_bga
Audi A3 / S3 / RS 3
Jan 29, 2013 10:56 PM
Paracaidista2.7T
14
Jul 10, 2011 05:31 PM
deongamer
Sep 16, 2010 09:53 AM
Jason Chen
Sep 2, 2004 11:10 AM
