simple question...
Old Dec 10, 2003 | 04:13 PM
JDreher's Avatar
Default simple question...
Perhaps my searching skills are lacking...but...I'm looking for some sort of dimensions on the oil drain plug crush washer for my 99.5 1.8t. Yes, I know it's been asked before but the only answer I've seen requires going to the dealer and doesn't mention any sizes. I pretty far from a dealer, though, and don't have much time. Right my only option is to go to AutoZone and pick one out of a tray with a whole bunch of different sizes (and they can't look up the size for me either). Any help would be much appreciated.
Thanks
Old Dec 10, 2003 | 04:20 PM
MikekiM@PureMS's Avatar
Former Vendor
Default 2 sizes..
20mm OD and 31mm OD.
Someone could probably tell you which one your car uses..
Offhand I believe it's the smaller one, which has an ID of like 14mm I believe.
Old Dec 10, 2003 | 04:23 PM
JDreher's Avatar
Default thank you much
the most specific I was able to find before was "about the size of a nickel (not a quarter)" so that 14/20mm one seems to match
thanks
Old Dec 10, 2003 | 04:29 PM
ArandA4's Avatar
Default in inches OD=.78 ID=.56
measured one of the ones in my glovebox
Old Dec 10, 2003 | 04:33 PM
ArandA4's Avatar
Default FYI
if you have to err one way or another, keep this in mind.
the ID is just big enough to fit over the threads. so go a little bigger if you have to.
the OD is just small enough to fit in a recess in the oil pan. so go smaller if you have to.
Old Dec 10, 2003 | 04:48 PM
JDreher's Avatar
makes sense, thanks
ds0
May 7, 2008 10:54 AM
kirklake13
Q7 MK 1 Discussion
Jul 22, 2006 05:08 AM
alekaras
Audi A3 / S3 / RS 3
Aug 7, 2005 09:23 AM
Keggie
Auto Detailing Discussion
Aug 19, 2004 04:29 PM
