Socketed vs Non-socketed chips
a non-socketed chip is usually where they physically load the software onto the stock chip by removing it, programming it, and then re-soldering it on.
The non-socket guys claim that their method is better because if you open the ECU, it looks stock, and there's no encryption to worry about.
i used to have a non-socketed chip, which I removed when I got the Tip chip (I went with GIAC for the new fuel chip), and I can tell you that it's VERY obvious that the chip has been removed.
APR is soldered
GIAC is socketed
APR will tell you that 'the reliablity of a socketed chip is not as good as a soldered one.' i.e. you have to worry about more than one connection between the chip and the ecu - you be the judge.
the apr chip is pretty obvious when you open it up. they do not simply flash the stock chip and put it back in. you do not need to have anything resoldered to upgrade your programming - you can even do it by internet with their at home kit.
you can use the tip chip with any ECU chip.
GIAC's remote kit will include a battery operated remote and a reciever in or near the ECU.
APR's uses the cruise control stalk to change programs (no it doens't mess anything up)
i say choose who is nearest to you, customer service is always important, they are both good chips.
