Speedometer doesnt work
Old Sep 14, 2008 | 11:28 AM
kholland's Avatar
Default Speedometer doesnt work
i have a 1996 a4 2.8 and the speedometer stop working. Everything else on the instrument cluster works. check fuses everything was good. Swapped the instrument cluster with one i know that works and still had the same problem. Can someone please help.
Old Sep 14, 2008 | 12:38 PM
Joao's Avatar
Was it right after an oil change?
Joao's Avatar
Default Here. Hope it helps.
<ul><li><a href="https://www.audiworld.com/tech/eng11.shtml">https://www.audiworld.com/tech/eng11.shtml</a</li></ul>
Old Sep 14, 2008 | 12:41 PM
@wesome's Avatar
Default thought about that... but 2.8L location for oil filter != same as 1.8L location
wondering if VSS (Vehicle speed sensor) became unplugged somewhere. Not sure where it is on a 12v though
Old Sep 14, 2008 | 01:09 PM
velosouljah's Avatar
Default yeah u correct. really no chance of catching anything on 12/30V except
maybe one of the ps lines
Old Sep 14, 2008 | 01:17 PM
depending on your tranny you can check to make sure vss is in and of course vag-com is prob good too
Old Sep 14, 2008 | 02:05 PM
Hillbilly's Avatar
Member
Default You *could* also tap the VSS wire in the main block. Drivers side kick panel. I have a schematic
showing the location of it. If you need it, let me know and I can dig it up. Might be easier to see if it has signal here rather than at the trans.
Old Sep 14, 2008 | 03:06 PM
kholland's Avatar
does anyone have a diagram of where the vss is located? cant find it in the manual
Old Sep 14, 2008 | 03:07 PM
kholland's Avatar
No
Old Sep 14, 2008 | 05:20 PM
Default in Bentley it is the last topic or close to the last topic under the "transmission" sections in
the index in the back. Don't paper Bentley's suck to search through?
oli1983
Oct 21, 2009 02:11 PM
Audi_8890
Sep 22, 2006 04:32 PM
cgray231981
Jan 2, 2006 04:35 PM
Jon-1.8t
Oct 7, 2005 06:37 AM
dieRICEdie
14
Oct 31, 2002 09:36 PM
