split-wide angle mirror install.
Old Apr 10, 2002 | 01:07 PM
coolgirl's Avatar
New Member
Default split-wide angle mirror install.
sorry if this has been asked before.. but i was wondering what the correct way was to take off the mirrors to install the split wide-angle mirrors.
any help or advice would be most appreciated. thanks
TisH
Old Apr 10, 2002 | 01:30 PM
DaveD4's Avatar
Default Re: split-wide angle mirror install.
The mirror glass is a press fit into the mirror housing. Some have suggested using a couple of allen wrenches as hooks to go behind the glass and pull. I tried this on mine, and didn't feel comfortable pulling real hard with such a narrow contact patch. I dug up a couple of L-shaped pieces of aluminum about a half inch wide and used those to reach behind the mirror glass. I was able to comfortably pull off my old glass with these. Also, I put a blanket on the ground in the vicinity of the mirror just in case it got away from me. Once you get it loose, there are a couple of wires on the back that attach to the mirror heater that have to be disconnected.
Good Luck,
Dave
Old Apr 10, 2002 | 01:33 PM
pyite20v's Avatar
Junior Member
any pics please? I have almost crashed many a times cause I cant see in my blind spot
Old Apr 10, 2002 | 05:00 PM
EricB's Avatar
Junior Member
Default It's called an "aspheric" mirror. Look here.
<center><img src="http://pictureposter.audiworld.com/849/eb_aspheric.jpg"></center><p>Note the vertical line 1/3 from the outer edge. Also note the changing curvature of the image in the mirror.
It works great!
S4armer
Jun 29, 2006 10:28 AM
Audrenalin
Mar 4, 2004 05:23 PM
Matt Devo
Oct 5, 2003 04:35 PM
Audragon
Oct 1, 2003 04:03 PM
PitViper
Aug 21, 2003 05:07 AM
