squeek!
Old Jun 4, 2003 | 04:18 PM
NW Avant's Avatar
Member
Default squeek!
so I hit little bumps and I hear just a little chirp. It sounds like it's comming from the drivers front...New shock time? Control arm issues? I do have some bounce in my ride...like the floot-y feeling, not unlike my old cutless...hummm Ideas?
Old Jun 4, 2003 | 04:21 PM
ex-quattro PETE's Avatar
AudiWorld Expert
Default try going over the same bumps with your foot lightly on the brake pedal...
If the noise is gone, it's your brakes - too much play room in the caliper cause the brake pads to jump around. Common issue.
Old Jun 4, 2003 | 04:29 PM
[ej257]'s Avatar
Member
Default agreed. had the same "squeek," and thought it was the control arms...turned out to be brakes
like you said
Old Jun 4, 2003 | 04:34 PM
NW Avant's Avatar
Member
yeah I'll check that out thanks....we'll see/hear
Old Jun 4, 2003 | 04:39 PM
AudiWorld Expert
Default were you able to get the dealer to fix it somehow? ...
I know if they put in new brake pads it'll make the noise go away since there won't be any room for the pads to roam around anymore, but that is not exactly a solution per se.
Old Jun 4, 2003 | 04:51 PM
[ej257]'s Avatar
Member
Default they took apart the breaks, re-greased, re-installed and tightened
the noise went away for about a year, and has just recently come back, unless it's the control arms or something this time.
Old Jun 4, 2003 | 04:56 PM
A4QuattroVT's Avatar
Member
how much did they charge you to do that?
Old Jun 4, 2003 | 04:58 PM
[ej257]'s Avatar
Member
warranty item...free
 Pouria Savadkouei
 Michael S. Palmer
Rudidudi
Jul 7, 2014 05:52 AM
WNT2FLY
9
Jun 11, 2013 01:41 PM
yiannaaudia4
Jan 21, 2006 04:13 PM
A4Turbo22
Jun 9, 2003 07:09 AM
Andrew Cohen
Dec 7, 1999 01:44 PM
