Stalling A4
Old Aug 6, 2004 | 06:22 AM
4redrings's Avatar
New Member
Default Stalling A4
Has anyone ever had a problem with there A4 stalling? If the car is in motion and I'm gasing it, everything is cool. If I release the gas, come to a stop or hold down the clutch, the car just dies. Initially I thought it was because I needed a tune-up but, it's still does the same thing.
Old Aug 6, 2004 | 06:37 AM
AudiMick's Avatar
Default Its broke...
..year, model, engine info might help. They made B5's from 94 thru 2001 (96 thru 2001 in NA) in several different configurations.
Old Aug 6, 2004 | 06:39 AM
4redrings's Avatar
New Member
Default Re: Its broke...
97 2.8 quattro. I think it might be my o2 sensor.
Old Aug 6, 2004 | 06:56 AM
AudiMick's Avatar
Default Idle control valve..
Most common problem on 12V. You can replace the valve for about $150 or clean it which works most of the time. Kris Hansen has a Web site with a cleaning procedure. Make sure you really clean it (use gumout) let the mechanical parts soak for an hour or so. Also try to replace your vacuum hoses as they are probably leaking by now.<ul><li><a href="http://www.kris-hansen.com/Audi/">Kris's web site</a></li></ul>
Old Aug 6, 2004 | 07:03 AM
Mr Paul [T-28]'s Avatar
Junior Member
Default Yep ICV, same thing happened to me. Exact same symptoms too.
I ordered mine from ECS for about $190. Kris Hansens page helps tremendously
Old Aug 6, 2004 | 07:47 AM
4redrings's Avatar
New Member
Thanks guy's for your advice.
lilman05
Jan 24, 2006 05:25 PM
YumyJager
Dec 15, 2002 04:10 AM
RomanQ7-2007
Dec 11, 2000 08:16 PM
