Stalling in neutral
Old Dec 19, 2002 | 02:55 PM
marcp's Avatar
New Member
Default Stalling in neutral
I cleaned out my ICV 4 months ago and recently the stalling started to happen again. I notice it has been happening after driving on the highway. Does anyone think its my ICV?
Old Dec 19, 2002 | 03:12 PM
paul_858's Avatar
AudiWorld Expert
i c v?
Old Dec 19, 2002 | 03:22 PM
marcp's Avatar
New Member
Idle Control Valve
Old Dec 19, 2002 | 03:28 PM
Dead's Avatar
Elder Member
It could be. Check /replace all vac. lines if they are orginal.
Old Dec 19, 2002 | 03:34 PM
lazybeans's Avatar
Junior Member
maybe reset to a higher idling rpm
Old Dec 19, 2002 | 04:22 PM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Could be, or you might need a new valve. On our car, it eventually just crapped out...
Check the resistance across the terminals, if it's not between 7 to 11 ohms, replace it.
Old Dec 19, 2002 | 04:24 PM
marcp's Avatar
New Member
Default Where can I find instructions about vac. lines?
Also if I need new lines, what size? Do I need any connectors?
Old Dec 19, 2002 | 05:00 PM
Dead's Avatar
Elder Member
If they are original,they need to be replaced. Just do one at a time.
Old Dec 19, 2002 | 05:52 PM
marcp's Avatar
New Member
Default Re: If they are original,they need to be replaced. Just do one at a time.
What size vacuum line and what material? Do I need any sort of connectors or does it just slide on?
Old Dec 19, 2002 | 06:48 PM
Dead's Avatar
Elder Member
I used silicone with a 3mm ID.No.Yes.
