Stereo install
Old Jan 19, 1999 | 12:15 PM
SandyK
Guest
Posts: n/a
Default Stereo install
Finally semi-completed my stereo install. Right now I have the Scosche face plate but will replace it soon with an anodized aluminum bracket. The Scosche plate looks fine but if I was to keep it, I would have to enlarge the opening a bit because when the faceplate opens, the Scosche will pop out. The radio you see is the Sony XRC-900 Mobile ES unit.
Old Jan 19, 1999 | 12:17 PM
SandyK
Guest
Posts: n/a
Default Pix of Amp
Phoenix Gold M44 amp ~ 40 Watts per channel.<br>The wiring isn't quite complete.<br>
Old Jan 19, 1999 | 12:20 PM
SandyK
Guest
Posts: n/a
Default Re: Pix of Amp and CD changer
I really didn't plan on putting changer there but, it wouldn't fit in the CD changer compartment. It was too wide by 1/2" (@#$@%!). I didn't want to spring for the Sony 6 disk changer.
Old Jan 19, 1999 | 12:22 PM
SandyK
Guest
Posts: n/a
Default Pix of MD changer
Here is a picture of MD changer.
Old Jan 19, 1999 | 12:24 PM
SandyK
Guest
Posts: n/a
Default Speakers
I'll try to get pictures of speakers. I have the MB Quart RSB 215 in the front and stock speakers in the rear doors. I'm not totally satisfied with the sound of the MB Quart. It sounds too harsh with no midrange/bass presence. I might have to put an equalizer in there.
Old Jan 19, 1999 | 02:27 PM
MarkF
Guest
Posts: n/a
Default Re: Speakers
Do you have the Reference model MB Quarts? I have the base model Autobahn 6.5" component set, and I think they sound awesome. I am also powering them with a M44, and I have a small 5-band Kenwood equalizer(maybe that helps). Have you considered adding a sub or two for low-end? JL Audio subs compliment the Quarts really well.
Old Jan 19, 1999 | 02:34 PM
SandyK
Guest
Posts: n/a
I have the Referenz Comp series. They don't sound too good unless it is really loud. The midbass isn't loud enough or the tweeters are too loud. I've turned down the treble and that doesn't seem to help. I've turned up the bass and that helped a bit. I think it needs an EQ.<p>I plan to use the factory subwoofer again. I'll probably bridge the M44 to power just the fronts. I'll then tap into the factory harness to power the rear door/subwoofer.
Old Jan 19, 1999 | 03:59 PM
Rob B.
Guest
Posts: n/a
I have a similar setup. However, with the MB Quarts up in front, Boston Acoustics in the rear, and JL Audio 10" subs -- all controlled by the small Kenwood equalizer. With the subs, I don't have to worry about enough bass coming through the other speakers. In any event, the EQ functions as a low frequency crossover for the front & rear speakers when the subs are engaged.
Old Jan 19, 1999 | 07:10 PM
Chris C
Guest
Posts: n/a
Default Re: Stereo install
Sandy,<br>Thanks for the pics, the stereo looks really good. Where are you getting your anodized aluminum bracket from? Do you think this will be a better fit? Any idea on cost?<p>Thanks,<br>Chris<p>Ps. Please post pictures when done.
Old Jan 19, 1999 | 09:00 PM
SandyK
Guest
Posts: n/a
The aluminium bracket is made by a friend of mine. Right now it cost about $70 with the anodizing. I needed to shave 1/32" off the thickness now. The fit should be better. I'll get pix when ready.<p>Sandy
mtl expos RIP
Jan 30, 2003 06:38 PM
joe@vwvortex
Feb 19, 2002 12:10 PM
George
Oct 28, 1999 12:38 PM
Rob C
9
May 27, 1999 08:20 PM
mshan
Mar 13, 1999 07:53 PM
