still starting problems......
Old May 8, 2008 | 05:26 PM
mgriffiths05's Avatar
New Member
Default still starting problems......
1996 2.8Q...when i try to start the car, as soon as the key is turned to the on position the fuel pump relay starts buzzing (loud)..if i try to start the car it will turn over but will not fire.....i replaced the fuel pump relay and i still have the same symptoms....any ideas guys???????
Old May 8, 2008 | 05:56 PM
a4_1.8t_01's Avatar
Default If its still buzzing then you might have a short where the relay goes into.
See if you can take it apart and see if any tabs are touching eachother.
Old May 8, 2008 | 05:57 PM
JAFO's Avatar
i'd test the fuel pump. i'm not sure how to do that. any codes?
Old May 8, 2008 | 06:04 PM
B5Davem's Avatar
Default if the pump itself is bad try tapping on the tank with screwdriver handle...
If it starts it verifies that the pump is bad. This works sometimes if the brushes or armature are bad in the pump motor. I've driven a car for two weeks before replacing the pump because it started everytime that I had to hit the tank. It finally stopped working completely.
Old May 9, 2008 | 04:42 AM
New Member
i don't have a code reader...but there is no engine light.
Old May 9, 2008 | 04:52 AM
New Member
also, how does the plastic stuff under the steering wheel come off?
Old May 9, 2008 | 05:12 AM
ianbis's Avatar
Default there is a shrader valve port near the FPR hook up a FP gauge to it and check the pressure, I'll pos
t values you should be looking for, when I get a momemt
200tqdan
Jun 24, 2010 03:56 PM
audidrvr
Audi Original "S" Cars
14
Mar 29, 2009 03:16 PM
Shadowfax
Nov 29, 2007 12:32 PM
Khris
Audi 100 / A6 (C4 Platform)
18
Mar 20, 2004 08:48 AM
9394Audi90
Oct 6, 2003 06:04 PM
