stoptech problem (long)
anyway, my problem is that i've been getting a noise from the wheel area that can best be described as a "clicking" that would happen at every rotation of the wheel. it would do it at all speeds, but if i tapped the brakes, it would stop momentarily. it seems to usually occur from the passenger side wheel, but will occasionally be audible from the driver's side, or both.
if i brake hard and come to a complete stop, the clicking noise happens very rapidly upon moving again, not in rhythm with the rotation of the rotor/wheel. this leads me to believe it's coming from the caliper.
i removed the passenger side wheel yesterday to check it out, and there's nothing hitting the wheel or the rotor, there's nothing on the tire, and i examined the brake system and there doesn't seem to be anything out of the ordinary. there is no scoring on the rotors that i can see, and the pads are securely in the caliper.
since doing that yesterday, the clicking has gotten louder and turned into more of a scraping, since it's longer instead of a short click. if i roll down a hill very slowly with the brakes, as it hits that one rotation in the rotor, i can hear the noise. when it's this slow, it sounds more of a "crunching" noise, although when it speeds up (a few mph), the crunching noise turns into the clicking (and now scraping) that i'm hearing.
the crunching noise i'm hearing is the same noise that is heard when i connect a vag-com to the car and enter the brake system module. i don't know if that helps explain it at all.
i'm out of ideas on what it could be and i don't really want to guess and replace every component until it stops. anyone heard of this before?
i emailed this to matt at stoptech but haven't heard back yet, just thought i'd give it a shot here.
2. In case it is just the pad friction material hitting the slots on the rotors, you can chamfer the leading edge of the pads.
3. This occurs in a straight line as well correct? (just eliminating the possibility of a CV joint issue)
4. How worn are the rotors? Is there a ridge on the outer edge? How thick is it?
Do your pads have a metal backing plate? are the backings secured or loose?
took the wheel off and saw that it was just the clip.
If you show me a pic of the top of the caliper I can show you exactly what I mean
